Re: Dome or flat top
[Re: 68post]
#1239938
05/26/12 10:10 AM
05/26/12 10:10 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Depends on what you want for compression and what cylinder heads are going to be used.But to answer the question... I like using a flat top piston.
[Re: 68post]
#1239939
05/26/12 10:14 AM
05/26/12 10:14 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
There is no reason for a dome piston if you can get the CR you want with a flat top,alcohol runs best with the CR 15-15.5-1 some go as high as 16-1. Most of the time to get the CR that high you will have to at least run a step dome on your piston.It depends a lot on what CC your heads are,I would have them milled down as much as possible to be able to use a FT or at least keep the dome as small as possible.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: 68post]
#1239941
05/26/12 10:59 PM
05/26/12 10:59 PM
Posts: 5,620 long island NY
Ari440
long island NY
with a RB 511ci, 0 decked ,flat top piston 7cc valve reilef and 71 cc chambers INDY 440-1 HEADS is 13.1 compression
1.39 9.85 - 137 mph
[Re: Ari440]
#1239942
05/26/12 11:53 PM
05/26/12 11:53 PM
Posts: 2,524 PA
moparacer
PA
I have a dome in mine to get the compression up with uncut 440-1's.
I had the domes on a set of cast Iron heads which couldn't be cut to up the compression.
When I build another shortblock I will go with a flat top and mill the heads.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Ari440]
#1239944
05/27/12 01:02 PM
05/27/12 01:02 PM
Posts: 16,930 NC
440Jim
NC
My 440-1 heads are milled all the way to 68cc bringing the CR up to about 13.5. To get higher you will need a small dome on the piston, but alky runs fine at 13+ CR.
[Re: JohnRR]
#1239949
05/30/12 12:57 PM
05/30/12 12:57 PM
MRMOPAR622
Sweet Home Alabama
My 572-13 heads are 60cc no problems what so ever with them,would have no problem at all milling another set down to 60 cc. My pistons set .020 down in the hole and have a .100 step dome and with .042 cooper head gaskets the CR is 15.3-1. The step dome is nothing like the old style large looking dome(TRW L2295)piston,in fact even out of the engine block if you do not have a sharp eye are were not shown they had a dome you would never notice it,it appears to be a flat-top not dome piston. If I were you I would mill the heads and use step dome pistons and get the max HP out of my engine.
