No. Electronic ignition or points? Can you measure the voltage at the positive terminal of the coil both when the key is on and when you are cranking the motor, and post the results? It should be around 12 when cranking(start 2) and 7 or 8 volts when on(start 1).
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
