What Are We Using For Break-In Oil These Days? #1239191
05/24/12 10:29 PM
05/24/12 10:29 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
I was going to use Rotella on my fresh build (PONTIAC! )
Any other suggestions? Purple Power?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239192
05/24/12 10:30 PM
05/24/12 10:30 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I use Rotella and a bottle of Comp Cams break in lube.
Re: What Are We Using For Break-In Oil These Days? [Re: JoesMopar] #1239193
05/24/12 10:42 PM
05/24/12 10:42 PM
yeah thats what I was planning on doing
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239194
05/24/12 11:25 PM
05/24/12 11:25 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
New cam break-in I just use cheap wallmart oil & a bottle of whatever favorite additive. Then for under load driving on a new engine I'll drain the old cheap stuff and use Amsoil. Tight clearances 5w30, loose 15w-40. IF yours is a Pontiac 400 then straight 50 weight
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: What Are We Using For Break-In Oil These Days? [Re: DARTH V8Я] #1239195
05/25/12 08:34 AM
05/25/12 08:34 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Ow.
Re: What Are We Using For Break-In Oil These Days? [Re: BSharp] #1239196
05/25/12 08:59 AM
05/25/12 08:59 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
by "purple power" I'll assume you meant "royal purple"? I have some killer degreaser/floor cleaner soap thats called purple power. I don't think that would make a very good break in oil, but it will wash away all your assembly lube in short order!
I wouldn't use the purple stuff, I believe it's all synthetic oil, and was not aware that the purple stuff came in a conventional oil?
I did run the purple synthetic in my flat tappet big block after break in on the engine dyno and 1000 street miles, never had a problem.
**Photobucket sucks**
Re: What Are We Using For Break-In Oil These Days? [Re: 70Cuda383] #1239197
05/25/12 09:18 AM
05/25/12 09:18 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
30 Weight Brad Penn
MLR426
Re: What Are We Using For Break-In Oil These Days? [Re: DARTH V8Я] #1239198
05/25/12 09:39 AM
05/25/12 09:39 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
+1 for wally world oil
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239199
05/25/12 09:43 AM
05/25/12 09:43 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My newest cam (2 weeks) I used Delo 400 LE plus a bottle of the Comp cams break in additive. My previous cam, Rotella T with a bottle of the comp cams additive. These were medium to large hyrdaulic flat tappet cams with Edelbrock heads and springs.
Re: What Are We Using For Break-In Oil These Days? [Re: Exit1965] #1239200
05/25/12 09:47 AM
05/25/12 09:47 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I just broke mine in with the Brad Penn 30wt break-in oil with a bottle of the Comp Cams break-in lube additive. It went perfect.
Re: What Are We Using For Break-In Oil These Days? [Re: bobs66440] #1239201
05/25/12 10:02 AM
05/25/12 10:02 AM
PA
noplanb Offline
noplanb  Offline
PA
+1
remember when you said honey, some day that car is gonna look so good in front of our house
Re: What Are We Using For Break-In Oil These Days? [Re: DARTH V8Я] #1239202
05/25/12 11:16 AM
05/25/12 11:16 AM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Just a quick note, Wallmarts 'supertech' oil is just re-packaged Penzoil.. just alot cheaper. After a cam break-in, I change the oil/filter and check for contanements.. So I just don't see the point of using and expensive oil for a no-load cam break-in that I'm gonna change right after.
Re: What Are We Using For Break-In Oil These Days? [Re: DARTH V8Я] #1239203
05/25/12 12:16 PM
05/25/12 12:16 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I used Comp Cams break in oil for the cam break in, changed it for more Comp Cams break in oil for the first 500 miles or so (as per the suggestion of someone on Comp Cams tech line), then changed it to Valvoline VR1 with some ZDDP additive. So far, so good.
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239204
05/25/12 01:30 PM
05/25/12 01:30 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Brad Penn Break-In Oil
Re: What Are We Using For Break-In Oil These Days? [Re: SILVER67] #1239205
05/25/12 01:57 PM
05/25/12 01:57 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Last two break-ins over the past year, I have used the Brad Penn 30wt oil made for this purpose, no need to add anything else to it.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: What Are We Using For Break-In Oil These Days? [Re: SILVER67] #1239206
05/25/12 02:28 PM
05/25/12 02:28 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239207
05/26/12 10:49 AM
05/26/12 10:49 AM
Brad Penn it will be
I need to fill it today so I can bar it over to attach the torque converter and trans and I will finish putting the carb, pulleys, etc back on, then Monday I can send it out for the exhaust and next weekend is the startup
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
Re: What Are We Using For Break-In Oil These Days? [Re: RangerDan440] #1239208
05/26/12 11:14 AM
05/26/12 11:14 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
break in oil
I used this on my 440 in the Ramcharger.
Moparlee
