Not sure if you have to replace the piece on the fire wall, but you will definitely need a new pedal rod. I just sold a '70 booster with all the linkage on it, here is a pic for reference of what it looks like off the car. If you need an adapter will depend on which style master cylinder you go with, old style iron or one of the aluminum pieces. You might check over on the parts for sale board for an aluminum piece if you are going that route. I bought one from Rick Ehrenberg off there a while back for a good price, not sure if he still has some more. Good luck with the swap.
