r- block build question
#1237778
05/22/12 04:12 PM
05/22/12 04:12 PM
Posts: 210 mass,usa
sickhemi
mass,usa
been side tracked for too long time to order pistons. i have a tall deck 59deg r3. i have a billet 3.55 stroke crank and i have too sets of rods.first set of rods carrillo 6.525 lgth .927 pin 2.1 big end 800grms second set k1 6.123 .984 pin 2.125 big end 720grms. should i grind the crank to 2.100 and use the carrillo rods with a 1.28 compression height piston or go with the k1 rods with 1.680 comp height piston. the motor is going in a dart for the street with procharger 8lbs boost port injected efi and mild roller cam .525 lift 230 duration .050
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: r- block build question
[Re: 408strokerdart]
#1237781
05/22/12 06:54 PM
05/22/12 06:54 PM
Posts: 210 mass,usa
sickhemi
mass,usa
the car will be my daily driver in good weather not raced every weekend the engine will have 10.5-1 compression, aluminum heads boost shouldn't be an issue with 8 lbs max.on the street the engine will rarely see boost and only start to see boost above 3000 rpm with a standard transmission.
[Re: sickhemi]
#1237782
05/22/12 08:20 PM
05/22/12 08:20 PM
Posts: 126 mass
kotacars
mass
sell both sets and get Carrillo h beam 6.200
[Re: kotacars]
#1237783
05/22/12 10:19 PM
05/22/12 10:19 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Hope you don't want to run that on pump gas.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dizuster]
#1237785
05/24/12 07:22 PM
05/24/12 07:22 PM
Posts: 210 mass,usa
sickhemi
mass,usa
with water/meth injection and the fuelinjection it should be fine at 10.5-1 the question was about the connecting rods and pistons. would you run a heavier rod and light pistons or the lighter rod with a heavier piston?
#1237786
05/24/12 11:11 PM
05/24/12 11:11 PM
1967dartgt
Hilltown Pa
I would run k1 rods and large piston ch.
