Re: Original or not fender tag?
[Re: KWF340]
#1237535
06/06/12 05:46 PM
06/06/12 05:46 PM
Posts: 1,037 The New Jersey Hinterlands
Sssnake383
Old and boring
Old and boring
Looking at this '69 bee and wondering if the fender tag is legit. Were inspection stamps/punches typically found in '69 St. Louis cars?
As others stated, the tag in the picture is missing the commonly seen stamps and inspector's punches commonly found on St. Louis tags, and apparently is unbent. 1969 St. Louis tags were usually bent.
I've never seen a (genuine) tag with the G15 tinted windshield code. That would be on the broadcast sheet only, AFAIK. Also, I think that G31 and G33 codes would not be called out on the fendertag, either - broadcast only.
I'd be doubtful.
[Re: Dougsmopars]
#1237537
06/06/12 08:56 PM
06/06/12 08:56 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
trimtags There are 5 samples of MOPAR tags pictured on the web site - after a quick look 4 of them have errors, were these inspected by his OE judge? I know a little about Oldsmobiles - he's guessing there also.
[Re: 6bblgt]
#1237538
06/06/12 09:18 PM
06/06/12 09:18 PM
Posts: 406 California City, CA
dart440
California City, CA
So some personal research into what is correct/incorrect is in order before having them do a tag for you. Ensure only codes appropriate for your vehicle are on the tag, some items on broadcast sheet do not go on the tag (i.e.; not all options go on the fender tag). Ensure all codes that are supposed to be on the tag are there. Ensure the codes are in the correct sequence (placement) on the tag. Scheduled Production Date and Vehicle Order Number (VON) would be only a guess if you don't have a broadcast sheet. You can get close by looking at other cars from the same plant with close VIN sequence numbers, but without a Broadcast sheet or other documentation, they will just be a guess. Finally, you'll have to figure out what inspector stamps (punch-outs) that you will need to replicate for the St. Louis plant are common for your vehicle.
When you work on Spaceships for a living, how bad can a workday be?
[Re: dart440]
#1237539
06/06/12 09:45 PM
06/06/12 09:45 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Some people guess when they don't need to. Even with what appears to be an original broadcast sheet who ever made/ordered the tag guessed on the VON. 69 bee
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: Sssnake383]
#1237540
06/07/12 12:19 AM
06/07/12 12:19 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I'd be doubtful.
Wrong, G31 and G33 will be called out on a STL car, this car is 1 after my 500 vert, my tag is missing, a new one will have NEWTAG in place of the order number
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1237542
06/07/12 09:16 AM
06/07/12 09:16 AM
Sssnake383
Old and boring
Old and boring
Okay, thanks for the correction...as I said "I think..." as I wasn't positive about the mirror codes being called out. Still, no G15 code on a St. Louis tag.
Post deleted by moparts
[Re: 69CoronetRT]
#1237544
06/11/12 12:40 PM
06/11/12 12:40 PM
[Re: 69CoronetRT]
#1237546
06/11/12 03:38 PM
06/11/12 03:38 PM
#1237548
06/11/12 03:57 PM
06/11/12 03:57 PM
6bblgt
Las Vegas, NV
I have a friend who was sales manager over a dealership that sold new a 1969 daytona. He said they couldn't sell the car so they took the wing and front end off and threw it in the dumpster. Really. They threw the parts away. The DMV has the car listed as an xs and not an xx. We checked with the head guy at the DMV and he said the car is registered as an xs. He said they never would have given the same last 6 sequence numbers to 2 different vehicles so it had to be the same car.
The who/what/where of most Daytonas are well known - any specifics of this particular car? Dealership/fender tag/VIN info??
lots of stories - few with any evidence or proof
