Re: Leaf spring question
[Re: HemiChallenger]
#1236903
05/21/12 12:07 PM
05/21/12 12:07 PM
Posts: 5,392 Pikes Peak Country
TC@HP2
Pikes Peak Country
What i was thinking of doing if possible is putting two right hand springs on the back of my challenger that are the 7 leaf ones. So given they would be the same i would imagine that to be okay?
Ohy yeah, that is fine and is an easy way to step up rate and control.
[Re: fal3]
#1236906
05/21/12 08:52 PM
05/21/12 08:52 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
IIRC, somebody had asked this question in the Cornering forum, and it was suggested by a respondee that to make the older, heavier Mopars handle better, matching the number of leaves on the springs per side was a benfit to improved handling. But I'm working on memory here; I'd read the post a while ago. Should be in the Archives (?) or Search.
That may have been one ov my questions that turned into a small book.
To balance out the weight bias (for cornering) i might actually take the stiffer spring and put it under my ass instead ov on the passenger side. Seems a bit backwards, but thats the compromise i guess. I'd rather it handle better every single day then hook at the track the one time in 7-8 years i actually bother to try and drag race it.
I would prefer to have matching springs on both sides though... i just happen to have two different rate springs... like you do.
