Re: what alum radiator to get for a B body.
[Re: kruger]
#12388
07/18/04 08:16 PM
07/18/04 08:16 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
the radiator is mounted in all stock holes that were on the upper and lower core supports. on the upper core support the holes were just a hair smaller than 1/4" so I just opened them up to 1/4", and for now I have a 1/4" bolt with washers but I am going to make the proper alum spacers for it. then the lower plate is a piece of alum that I bent into a 90* piece and bolted it to the holes in the lower pan then drilled it and the radiator and bolted them together. the only thing that I had to modify was on the driver side there is a raise area the made the radiator stick out towards the back of the car so I cut a small area out of it to make it set flat.(see the picture below) If you did not want to cut anything all you would have to do is make the spacers a little longer(around 1 1/2").Ron... the cut area is to the left side in this picture..
[Re: kruger]
#12390
07/18/04 11:53 PM
07/18/04 11:53 PM
i just ordered one too moparts discount...
[Re: nomore65BelvJim]
#12395
07/20/04 08:16 AM
07/20/04 08:16 AM
Posts: 1,031 South Jersey
kruger
Yours Too!
Yours Too!
South Jersey
Jim, I'm mounting it between the Rad and Grill. ( off center ) The No-Fan is good enough for the street Depending on the works in the trans IMO.
#12398
08/07/04 10:18 AM
08/07/04 10:18 AM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
Nice, looks like it'll fit good. I just put one in my 68 Satellite with the 26" rad suport and the bottom brackets were in mid air in ht eradiator opening when the brackets were on the tanks. I ended up welding an extra 1 1/2" peice of flat stock to the sides of the J-brackets and that worked out great, every applications diferent I sopose, attatched is a picture.
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
[Re: 440Satellite]
#12399
08/07/04 10:24 AM
08/07/04 10:24 AM
440Satellite
super gas
super gas
Hazlet, NJ
And heres a picture of it all installed. It was running a little warm (almost 210)so I had to make a custom fan shroud. I picked up a 24"x28" peice of 20 gauge sheet metal and bent/welded up a fan shroud for it. It came out pretty good and the 440 now runs a constant 185!!!!!!!! Finally fixed my cooling problems.
Butch
1972 Duster
318 4 speed
#12402
08/07/04 11:08 AM
08/07/04 11:08 AM
440Satellite
super gas
super gas
Hazlet, NJ
Thanks, yeah I made the shroud by hand. I had an air nibler so the cutting was easy but I dont have a metal brake so I had to bend it all using peices of angle iron and clamps. Thats why it doesnt have sharp corners but I like it better that way.
65BelvJim, I've been folowing that thread on the T-bird fan setup. I was going to go that rought next if the shroud didnt keep it cool. I also changed the fan from the one in the picture which was a flex fan from Summit. I'm now running a 5 blade stock type flex fan, its got the pentastar on it so it must be a stock part. With this fan and the shroud it will suck your hand against the radiator when you hit the gas, it flows some major air. The car would get up to almost 210 with the Summit flex and now its a constant 185!!!
Butch
1972 Duster
318 4 speed
[Re: kruger]
#12404
08/07/04 11:39 AM
08/07/04 11:39 AM
440Satellite
super gas
super gas
Hazlet, NJ
Heres a picture of just the shroud, I had to clearence it on the lowwer drivers side for the Summit rads lower hose outlet. I'll get a picture of the fan I'm using if you want.
Butch
1972 Duster
318 4 speed
