Trans cooler ahead of radiator or after? #1236715
05/20/12 11:21 PM
05/20/12 11:21 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Should a auxiliary transmission cooler be plumbed before or after the radiator, that is the ?
Joe
Re: Trans cooler ahead of radiator or after? [Re: fuseable] #1236716
05/20/12 11:24 PM
05/20/12 11:24 PM
IN
ahy Offline
ahy  Offline
IN
Its usually best after. The cooler in the bottom radiator tank gets some heat out first. The added cooler gets more out with ambient air. Its a 2 stage setup.
Re: Trans cooler ahead of radiator or after? [Re: fuseable] #1236717
05/21/12 06:06 AM
05/21/12 06:06 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I run the trans cooler first than the radiator. More consistent trans temps in cold weather, and the radiator does not have to work as hard cooling the engine in hot weather. Running radiator first, your more likely to have engine overheating problems.
Re: Trans cooler ahead of radiator or after? [Re: 451Mopar] #1236718
05/21/12 08:14 AM
05/21/12 08:14 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
on the other hand when the water temp is up it will heat the tranny fluid if the cooler is before the radiator...
I recently got a transmission cooler with a thermostat that I plan on mounting after the radiator. The thermostat only opens when the tranny fluid reaches a certain temp so no worries about too cool fluid.
Re: Trans cooler ahead of radiator or after? [Re: DGS] #1236719
05/21/12 09:30 AM
05/21/12 09:30 AM
Andrewh Offline
Andrewh  Offline
there are actually 3 schools of thought on this.
first 2 mentioned.
before, so the rad will maintain a more consitant trans fluid temp.
after to cool a bit more than the rad can, as lower temps equal longer life.
third is to bypass the internal rad cooler all together.
A couple of aftermarket transmission companies recommend this option because of 1. the transmission can never cool further than your radiator temp using that internal cooler vs the external cooler that can go to ambient.
plus concerns for gunk in the cooler and some radiators are know for leakage.
I was always taught to do the first one. but after reading a few articles like that I will always get a bigger aux cooler and leave the radiator one out of the loop.
Re: Trans cooler ahead of radiator or after? [Re: DGS] #1236720
05/21/12 11:26 AM
05/21/12 11:26 AM
NY usa
540challenger Offline
NY usa
Wouldn't that cut off the fluid flow when t-stat is shut???
Re: Trans cooler ahead of radiator or after? [Re: 540challenger] #1236721
05/21/12 11:55 AM
05/21/12 11:55 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
No, as the thermostat has an internal bypass. It acts as a short piece of pipe when it's closed. when it opens the internal bypass is closed and the fluid has to go through the transcooler.
I'm going to use a Mercedes A-class transmission cooler. here's a pic:
Re: Trans cooler ahead of radiator or after? [Re: DGS] #1236722
05/21/12 12:47 PM
05/21/12 12:47 PM
NY usa
NY usa
Now that is a cool piece. Do you have a part number for that cooler??
Re: Trans cooler ahead of radiator or after? [Re: 540challenger] #1236723
05/21/12 03:37 PM
05/21/12 03:37 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I sure do - here it is: (A) 169 500 06 00
I accidently put up the picture of the newer cooler style. my cooler has part numer (A) 169 500 04 00 (or A 169 500 02 00).
here's how mine looks like (a bit different than the one before):
Re: Trans cooler ahead of radiator or after? [Re: DGS] #1236724
05/21/12 05:48 PM
05/21/12 05:48 PM
hooziewhatsit Offline
How wide are the mounting points?
Re: Trans cooler ahead of radiator or after? [Re: hooziewhatsit] #1236725
05/21/12 05:57 PM
05/21/12 05:57 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I would have to measure but the cooler should fit nicely in front of the radiator. if you line up one hole on the left(in the picture it's the lower one but the cooler is upside down) with a bolt hole in the radiator support the hole on the opposite (right) side almost lines up with another hole in the radiator support. I just need to weld a short piece of metal to the mounting tab with the rectangularhole and I can fit this cooler without drilling any new holes in the radiator support
