Who's running Dominators on the street?
#1236622
05/20/12 09:06 PM
05/20/12 09:06 PM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
I've been running my 505" with a Dominator on the street. It's always been a little rich (after putting in aftermarket metering blocks, before that it was WAY rich). I've been playing with it a bit lately and I seem to be making large changes in jet sizes for little change in A/F. The tuning forums suggested to start with a 85/95 jetting (with PV in front) as a baseline. I'm now at 78/88, and my A/F suggests I should still jet down further. Other specs are: Transfer slot restrictor: 0.055" PV channel restrictor: 0.089" Idle feed restrictor: 0.040" Idle air bleed: 0.082" Main air bleed: 0.026" Also has a high flow 6.5 PV in the primary side. Anyway, I thought I'd ask to see how people have their Doms jetted?
Re: Who's running Dominators on the street?
[Re: Damned67]
#1236623
05/20/12 09:30 PM
05/20/12 09:30 PM
Posts: 2,091 Delray beach, Florida
Performance Only
it's easier to find the proper changes by logging some ifo and posting it. idle rpm and a/f # off idle and a/f # no load 1500 rpm a/f loaded 1500 (cruise) rpm a/f etc. etc. i doubt you actually need a hi-flow power valve. i've never found it necessary on an 8896 dominator for street use.
machine shop owner and engine builder
[Re: Damned67]
#1236624
05/20/12 09:36 PM
05/20/12 09:36 PM
Thumperdart
State of confusion
8082-3 1050 86 ft. 96 r. 71 idle bleeds 28 hi speed bleeds 2.5 pv ft. only.............
[Re: ajcasini]
#1236629
05/20/12 11:33 PM
05/20/12 11:33 PM
Damned67
Tomorrow.
This is a two circuit carb correct?
Three circuit converted to two circuit.
[Re: Damned67]
#1236633
05/22/12 12:17 AM
05/22/12 12:17 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
I've installed .035 restrictors in the idle fuel and transfer fuel slots, it is way to lean now when cold, 15.9 to 20.+ depending on throttle position. this is a 9375 non HP two circuit that has been modified a bunch before I bought it, no power valves. I do have two other 9375-2 HP 3 circuits 1050 Dominator carbs., trying similar idle fuel and transfer fuel restrictor sizes to get a good part throttle cruise AFR, 14.2 or leaner
