605 is coming together #1236603
05/20/12 09:00 PM
05/20/12 09:00 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
It's been alot of stops and starts waiting for people and parts. Alot of massaging parts to fit but the motor is almost all together. Here's a few pics. Dave
Re: 605 is coming together [Re: quickd100] #1236604
05/20/12 09:07 PM
05/20/12 09:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow what kind of hp and torque are you looking at with that beast ? Thats sure gonna be nasty. Ron
Re: 605 is coming together [Re: 383man] #1236605
05/20/12 09:16 PM
05/20/12 09:16 PM
nielsville, minn.
Q
Q
nielsville, minn.
Ron; I'm not expecting that much. It's only about 10.5-1 and head limited. I'll be happy if it makes 800hp on my dyno. The cam is a Bullet solid roller .757/.676 288/292@.050 113 center installed @111. The heads only flow 386 on the intake. I'm going to try the Indy single plane and my 1140 dominator on the dyno first and then see what the Weiand tunnel ram does.Dave
Re: 605 is coming together [Re: quickd100] #1236606
05/20/12 10:12 PM
05/20/12 10:12 PM
Chesterfield Twp. Mi.
John Burdine Offline
i'm jealous.
Re: 605 is coming together [Re: quickd100] #1236607
05/20/12 10:15 PM
05/20/12 10:15 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That's gonna be an even bad'r FARM TRUCK! Cool!
"Any fool can know. The point is to understand"
- A. Einstein
Re: 605 is coming together [Re: EvilB1Dart] #1236608
05/21/12 04:01 AM
05/21/12 04:01 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
That is a monster engine! Very impressive. Cant wait to see the numbers.
Don
Street/Strip 73 Barracuda
Re: 605 is coming together [Re: The Cuda Guy] #1236609
05/21/12 05:58 AM
05/21/12 05:58 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Lookin good !!
Hanging out to see what it does as mine just came off the dyno as well..
Who's doing the work for you ?
Re: 605 is coming together [Re: LAD 524] #1236610
05/21/12 07:09 AM
05/21/12 07:09 AM
nielsville, minn.
Q
Q
nielsville, minn.
Lookin good !!
I'm doing the assembly, I had Quality Engine in Fargo hone the block. Very nice guys, know their stuff too but very busy, had to wait a couple weeks to get the block done.
I was going to use the solid roller I got for my 528 from Bob George but just couldn't get the p/v clearance I needed. I even had the valve reliefs cut at another local shop but in the end I had to go with something else.
I contacted Bullet Cams and they spec'd out the cam, that was another 3 weeks waiting. I have to say the cam was in my hands exactly 3 weeks to the day I ordered it, (he said he was running 3 weeks behind).
Had to redo all the installed spring height, also shorten the lashcaps on the intakes, relieve all the intake rockers for retainer clearance.
All the little details eat up time, and then of course there is family stuff and work. Dave
Re: 605 is coming together [Re: quickd100] #1236611
05/21/12 09:50 AM
05/21/12 09:50 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
What a beast, cant wait to see the numbers
Re: 605 is coming together [Re: racer_amx] #1236612
05/21/12 10:09 AM
05/21/12 10:09 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You will certainly have throttle response and velocity with only 387cfm head on an engine that big. Last one we did flowed just the other side of 500cfm....Wow looks good, and I will bet for the intended vehicle it will work just perfect, and probably break a few drive line parts in the process...Good luck and stay out of the weeds when you hit it the first time.
Re: 605 is coming together [Re: Dragula] #1236613
05/21/12 12:09 PM
05/21/12 12:09 PM
Lake Charles,Louisiana
BILLYJAY Offline
BILLYJAY  Offline
Looks Good.. must be a Tall ride to have such a DEEP pan on it....Let me know if you need a Dragster pan.IHave a Brand new one that hasnt been boilted on anything..had Magnum force notch the front corner and test...
Re: 605 is coming together [Re: quickd100] #1236614
05/21/12 07:44 PM
05/21/12 07:44 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: 605 is coming together [Re: ZIPPY] #1236615
05/21/12 09:43 PM
05/21/12 09:43 PM
tboomer Offline
tboomer  Offline
Lookin good,Dave!!
Re: 605 is coming together [Re: tboomer] #1236616
05/21/12 11:42 PM
05/21/12 11:42 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Which block ru using with this setup?
Re: 605 is coming together [Re: racerx] #1236617
05/22/12 12:03 AM
05/22/12 12:03 AM
nielsville, minn.
Q
Q
nielsville, minn.
The block is a MP siamese bore hemi block. I could have gone deeper with the pan but built a kickout on the passengers side instead. The bottom of the pan is just above the bottom edge of the trucks old straight axle. It's got a good 6" of ground clearance. It holds 12 quarts but I normally run 10 in it.
I'm hoping I've already fixed all the weak links in the driveline, I've already broke them all at least once. Dana 60 with spool and moser axles, built a 4-link as the 52 year old leaf springs gave up before I hit 600hp. New driveshaft, built a new trans crossmember with 2 triangulated trans braces. Bought a set of M/T radial drag slicks 32/14 for the track and have a new set of M/T 325/265-15's for the street.
The truck has given me more than a few 'Depends" moments, at 650hp it would break the street tires loose at 70mph. You soon learn to not drop the throttle until it's pointed in the right direction with the front tires pointed in the same direction. I've had it pointed at the guardrail at the strip enough times to know you can't drive through it. And you never, ever, ever race it or drive it at high speed in a cross wind. You never, ever excede 130mph unless you're looking to solo for your pilots licence, ( front end get air under it and the steering disappears.) Dave
Re: 605 is coming together [Re: quickd100] #1236618
05/22/12 12:19 AM
05/22/12 12:19 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Crazy stuff Dave, how long before it goes on the dyno?
Re: 605 is coming together [Re: quickd100] #1236619
05/22/12 12:34 AM
05/22/12 12:34 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
DAMN, That otta be fun..............
Re: 605 is coming together [Re: Thumperdart] #1236620
05/22/12 07:00 AM
05/22/12 07:00 AM
nielsville, minn.
Q
Q
nielsville, minn.
I'm hoping to have it on the dyno in a week or two. That thing called work keeps rearing it's ugly head. Right now I leave the house before 6am and am seldom home much before 10pm. Dave
Re: 605 is coming together [Re: quickd100] #1236621
05/22/12 07:17 AM
05/22/12 07:17 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Your work schelude is as bad as mine. Im 5pm to 7 am. Split days off tuesdays and saturdays. So I know how you feel when it comes to trying to finish the car.
