clutch safety switch????
same idea as the neutral safety switch.when the clutch is depressed it completes the ground, (i think, or it breaks the ground) either way....
if u have power at the IGN on position, then the problem isn't in your IGN switch (most likely). your powering your fuel pump so we can assume the IGN switch works, if u jump the starter relay does it turn over? (out of gear) if so then i would try to locate and isolate the clutch safety switch. its going to be something simple, it always is.... the longest most frustrating problems will be overlooked because "its too simple it cant be that"
