Wheel cylinder madness #1235430
05/18/12 01:40 PM
05/18/12 01:40 PM
South Jersey
JerseyJoe Offline OP
South Jersey
I know the reman. stuff is usually made to cross many applications, but the 10" front drum shouldn't be too exotic, right?
The front drums on my '70 Charger have a lemon-shaped hole in the backing plate and the old wheel cyl. is cast to fit in there nicely. These NAPA remanufactured (in USA) have more of a rectangular area on them.
I can try to rebuild the originals but they are pretty gacked up from sitting for a very long time. Would you cut the backing plate or not?
Re: Wheel cylinder madness [Re: JerseyJoe] #1235431
05/18/12 02:04 PM
05/18/12 02:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
http://www.rockauto.com/catalog/raframecatalog.php
There seem to be sevral types, and you have the wrong one.
WAGNER Part # WC106315 would seem to be the right one.
I have mechanical Aptitude.
I can screw up anything.
Re: Wheel cylinder madness [Re: bboogieart] #1235432
05/18/12 02:35 PM
05/18/12 02:35 PM
South Jersey
South Jersey
Thanks for the reply. I do have two of those, but they're for the rear brakes
Re: Wheel cylinder madness [Re: bboogieart] #1235433
05/18/12 02:35 PM
05/18/12 02:35 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Had the same problem, have them check the cylinders for a 69.
That's what I had to do....why? who knows!
Joe
Re: Wheel cylinder madness [Re: jlatessa] #1235434
05/18/12 02:39 PM
05/18/12 02:39 PM
South Jersey
South Jersey
Ahh, Joe you're right!
Mine was built in Jan. 1970, They must have had a TON of '69 parts left on the line
Re: Wheel cylinder madness [Re: JerseyJoe] #1235435
05/18/12 02:45 PM
05/18/12 02:45 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Sounds like your path is clear, but anyway, let me respond to the above question
NOT!
Down to just a blue car now.
Re: Wheel cylinder madness [Re: 68HemiB] #1235436
05/18/12 03:49 PM
05/18/12 03:49 PM
South Jersey
South Jersey
NOT!
I know... but I'd fab the hole the right way!
Re: Wheel cylinder madness [Re: JerseyJoe] #1235437
05/19/12 11:11 AM
05/19/12 11:11 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
On the Rock Auto link check toward the bottom of the w/c page,
they show what you're looking for.
