Total / Initial timing questions #1235394
05/18/12 11:36 AM
05/18/12 11:36 AM
S.W. Pennsylvania
markrr Offline OP
markrr  Offline OP
S.W. Pennsylvania
I'm sure this has been talked about before. Can someone please explain to me what total timing and initial timing is and what they do? I know what timing is and what the advance is for but the rest confuses me.
Thanks in advance.
Re: Total / Initial timing questions [Re: markrr] #1235395
05/18/12 01:07 PM
05/18/12 01:07 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Try this
The above and another article buried in this thread.
https://board.moparts.org/ubbthreads/show...rue#Post7184156
Re: Total / Initial timing questions [Re: markrr] #1235396
05/18/12 01:13 PM
05/18/12 01:13 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Total timing is the initial plus mechanical.
Initial is what you give it by twisting the Dizzy. Mechanical is what is built into the Dizzy mostly by the Bushing in the Dizzy.
An 18 degree bushing in my MSD dist. (dizzy) and twisting it so that pointing a gun at the timing marks shows 36 degrees means I have 18 degrees of intial.
Rev 'er up 'til the timing mark stops advancing. That is your total.
Think of initial like a timing preload.
Re: Total / Initial timing questions [Re: GwaiiEagle] #1235397
05/18/12 02:12 PM
05/18/12 02:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What's a dizzy?
Re: Total / Initial timing questions [Re: Challenger 1] #1235398
05/18/12 02:40 PM
05/18/12 02:40 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I am too lazy to look up how, and too ignorant, to spell distributor, sorry.
Re: Total / Initial timing questions [Re: Challenger 1] #1235399
05/18/12 06:35 PM
05/18/12 06:35 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
You dizon't knizow?
Re: Total / Initial timing questions [Re: Challenger 1] #1235400
05/18/12 08:23 PM
05/18/12 08:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What's a dizzy?
Easy answer !!
