Neon Head Gasket #1235217
05/18/12 12:52 AM
05/18/12 12:52 AM
Northern CA
streetkit Offline OP
Northern CA
Friend of mine is looking at Neons for his kid's first car. I know the older neon had head gasket issues, but when was that issue resolved? What model years would he want to stay away from? Thanks
1973 Dodge D100
Re: Neon Head Gasket [Re: streetkit] #1235218
05/18/12 01:38 AM
05/18/12 01:38 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
95-99 were junk, lots have been upgraded with the MLS gasket (standard after 00) witch you can clearly see with a quick look under the hood. If you look where the head gasket edge is, follow along till you see a bump sticking out with a rivet to hold the layers together.
