K Member interchangeability #1234916
05/17/12 01:31 PM
05/17/12 01:31 PM
louisville ky
67gtxclone Offline OP
louisville ky
are the K members on a 68 dodge charger and a 67 belvedere the same they both were 318 engines
Re: K Member interchangeability [Re: 67gtxclone] #1234917
05/17/12 01:37 PM
05/17/12 01:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The only difference is the idler arm mountiong point . you'll have to change the aidler arm if you are putting the 68 a 67 and vice verse ...
Re: K Member interchangeability [Re: JohnRR] #1234918
05/17/12 01:41 PM
05/17/12 01:41 PM
louisville ky
louisville ky
thanks will it make any difference moving the idler arm or should i just get the one for the 68 im putting the 68 in my 67 hopefully
Re: K Member interchangeability [Re: 67gtxclone] #1234919
05/17/12 01:44 PM
05/17/12 01:44 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Buy the 68 idler , it's not expensive and easy to get .
