Re: Who gets the credit......
[Re: jim sciortino]
#1234775
05/17/12 10:59 AM
05/17/12 10:59 AM
Posts: 6,148 Melbourne , Australia
LA360
There were racers working with Chrysler Engineers? Who were the first teams to run with the Hemi 99 engine? I was digging through some old photos and found some pics of the first look inside a Hemi 99 engine. I think Carl Foltz had some input into the P5, as Patterson's and others did alot with the P5 in the early stages. I remember David Rampy running a P5 engine prior to the SB2.2 stuff he runs now.
Alan Jones
[Re: LA360]
#1234776
05/17/12 02:17 PM
05/17/12 02:17 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Hmmmmmm....
Yeah, I've always wondered who were the minds behind the architecture.
[Re: jim sciortino]
#1234777
05/17/12 04:52 PM
05/17/12 04:52 PM
Posts: 1,019 Finland
mafo
Finland
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1234778
05/17/12 05:45 PM
05/17/12 05:45 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
Introduced in 2006, the Dodge Pro Stock, second-generation Hemi 99 was designated DPS2; despite having to accept existing components and fastener locations, the new engine, developed by Bruce Phillips and David James, was a leap forward in technology. Created by Chrysler engineers using CATIA version 4, the new engine uses compacted graphite in the iron block, greatly increasing strength and stiffness, and allowing for rounder, straighter cylinder bores that have better sealing and, therefore, higher efficiency. Thinner wall sections could also be used. With power levels near 1,400 horsepower, and valve lifts in the 28-29 mm range, engine breathing and sturdy, high-performance valve gear are extremely important. The engineers used CATIA to create a new Hemi head with canted valves, as well as ribs to strengthen the rocker arm attaching pad, and a thicker rocker stand with a new spread four-bolt design (the prior engine used three bolts). The intake and exhaust valves were both moved to try to make the valve train co-planar, reducing rocker arm side load and making the port trajectory more in line with the valve, improving the flow of fuel into the cylinders. Bob Glidden was called in starting in June 2005 to work on the challenges of making an engine that can push a car from 0-200 mph in just a quarter of a mile (and under 7 seconds); the NHRA was also called in for approval on the direction the engineers were taken. Cylinder head samples were provided by November 2005, and the first sample block showed up in December, with initial testing taking place in January 2006. Early testing showed an improvement of 15-20 hp over the previous design, a fairly substantial gain; and that was before optimization by the racing teams. Allpar Home | Engines | Origins of the Hemi |New 5.7 Liter Hemi
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: mafo]
#1234781
05/18/12 04:24 PM
05/18/12 04:24 PM
jim sciortino
Trumbull,CT.
maybe you are more familiar with Booble...
Slightly.
[Re: jim sciortino]
#1234782
05/18/12 05:28 PM
05/18/12 05:28 PM
mafo
Finland
The Pro Stock Hemi engine was introduced at the season-opening Winternationals of 2000. Only 16 weeks after it was first developed on a Chrysler engineer's computer screen, the new Pro Stock Hemi broke NHRA's national elapsed-time record with a 6.809-second blast in the night time air of Memphis (Tenn.) Motorsports Park. sure would be interesting to know who came up with the design
[Re: mafo]
#1234783
05/18/12 08:51 PM
05/18/12 08:51 PM
jim sciortino
Trumbull,CT.
Somebody has to know who did the design phase.
I'm not against waterboarding.......if I have to.
[Re: jim sciortino]
#1234784
05/18/12 09:45 PM
05/18/12 09:45 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I'll bring the bucket.Dave
[Re: quickd100]
#1234785
05/18/12 11:32 PM
05/18/12 11:32 PM
jim sciortino
Trumbull,CT.
