East Coast Alternator #1234700
05/16/12 11:27 PM
05/16/12 11:27 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Does anyone know the correct plug in the back to shut off of an East Coast Alternator 2026. There are 2 plugs and the main power wire.
Max Weg
Re: East Coast Alternator [Re: Max Weg] #1234701
05/17/12 12:03 AM
05/17/12 12:03 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there's a number of different configurations but the one you are referring to probably has a terminal for a idiot light and key on. if that's the case it should be terminal number two and this would be the on/off for the alternator.
these are most often Denso (Nippondenso) alternators and usually have some form of terminal identification. do some web searching and you should be able to confirm the connections.
Re: East Coast Alternator [Re: jamesc] #1234702
05/17/12 12:09 AM
05/17/12 12:09 AM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Awesome just what I needed!!
Max Weg
