best battery? #1234560
05/16/12 05:25 PM
05/16/12 05:25 PM
Nebraska
70VcodeCoronetRT Online tonguue OP
70VcodeCoronetRT  Online Tonguue OP
Nebraska
Looking for a new battery for my 70 challenger driver. Are they all about the same these days? I was looking at the restoration Turbo Start batteries. Thought they looked pretty cool. But 54lbs The red top Optima is only 38lbs. Thats 16 pounds off the front end. (still a bit of drag racer in me) What batteries are you guys happy with?
Re: best battery? [Re: 70VcodeCoronetRT] #1234561
05/16/12 05:27 PM
05/16/12 05:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Delco in the trunk!
Re: best battery? [Re: Challenger 1] #1234562
05/16/12 07:49 PM
05/16/12 07:49 PM
IN
ahy Offline
ahy  Offline
IN
Red Top in the trunk. For a driver with battery in the front, I would probably go to my usual source, Walmart, and get a "better" or "best" grade battery.
Re: best battery? [Re: Challenger 1] #1234563
05/16/12 08:03 PM
05/16/12 08:03 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Had an Optima 780cca in three cars....2 of them died prematurely. I brought one back to life using a light bulb trick....then it died a month later without a rebirth. I have a 540cca Delco and it spins the mini starter just fine., Never had a problem with it 3 years.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: best battery? [Re: Pyper70] #1234564
05/16/12 08:11 PM
05/16/12 08:11 PM
IN
ahy Offline
ahy  Offline
IN
The Red Tops were really reliable for a while then they seem to have gotten into quality problems. Now they reportedly have a handle on it again. When my sometimes abused 8 year old Red Top showed signs of being tired this spring, I tried another. We'll see.
Re: best battery? [Re: 70VcodeCoronetRT] #1234565
05/16/12 08:17 PM
05/16/12 08:17 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I've had 2 red top Optimas and they both died, Th word I hear that they are OK for a daily diver, but they don't like sitting unused for weeks at a time even with the cable disconnected I ended up with a Auto Zone Battery- no problems
Re: best battery? [Re: babarracuda] #1234566
05/16/12 11:04 PM
05/16/12 11:04 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Anyone use Odyssey Brand AGM?
Re: best battery? [Re: ramman5600] #1234567
05/17/12 12:53 AM
05/17/12 12:53 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
i bought Odyssey VRLA for my tractor this spring.
So far so good...only been 2 months though
Re: best battery? [Re: pacifica] #1234568
05/17/12 10:20 AM
05/17/12 10:20 AM
New York
rarefish Offline
rarefish  Offline
New York
I'm running a Odyssey motorcycle battery inside an old group 27 Mopar resto. battery. I think this is the 4th year that I have had it and so far no problems...
Re: best battery? [Re: 70VcodeCoronetRT] #1234569
05/17/12 08:06 PM
05/17/12 08:06 PM
Locomotion Offline
Locomotion  Offline
I put an Odyssey 1500 in the trunk of my race car a couple of years ago. I run a 50 amp alternator as required by the rules, but I charge between rounds during cooling anyway because of the electric fan and water pump. I liked it enough to buy pair of Die-Hard Platinum batteries for my 2004 Dodge diesel dually because they are manufactured by Odyssey, just relabeled - and less expensive!
I used Optima Red and Blue before with good luck, but now have the Optima as my auxilary trailer battery.
Re: best battery? [Re: Locomotion] #1234570
05/19/12 12:07 AM
05/19/12 12:07 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Any cross reference of links that shows the Odyssey compared to DieHard?
Re: best battery? [Re: ramman5600] #1234571
05/19/12 09:46 AM
05/19/12 09:46 AM
Locomotion Offline
Locomotion  Offline
I don't know of an actual # cross-reference chart, but the specs and casings are the same, just different colors. Sears seems to have the most popular versions in their Platinum line, not as many variations as the Odyssey labeled versions.
Re: best battery? [Re: Locomotion] #1234572
05/19/12 09:57 AM
05/19/12 09:57 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Being a GM sercive manager/tech, we deal in delco batterys. I can tell ya that they have really fallen off the deep end. This last winter we literally warrentied EVERY delco battery we sold. and 3 of them took 3 tries to get a decent one for the customer.
embarrassing, hell yes. Try keeping customers that way. Didnt happen. We had to give a few their money back, and havent seen them since.
The Delco rep who is a jackass came in every month and gave us grief every time till finally I took a battery, just a random battery he dropped of to us, took it over to a truck we were fixing the brakes on, and it wouldnt start the truck, just a fast click, click,click, then I tested it with our tester and his off his truck, 0cca, and 8 volts or something like that.
So from now on I tend to tell the good customer that still come in to us to let us sell them a John Deere battery. THose things are awesome.
The one in my dads van has been in there since 2004, and its still jsut as good as the day he bought it.
Re: best battery? [Re: Moparnut426] #1234573
05/19/12 10:15 AM
05/19/12 10:15 AM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
Used Mopar batteries for the longest time until the prices went through the roof. I am happy with the Interstate battery in my Dart for 2 years no problem. Also helps my friend carries Interstate at his shop and took a few bucks off it.
Re: best battery? [Re: Locomotion] #1234574
05/19/12 11:00 AM
05/19/12 11:00 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
But any of the platinum will be the exact same as the Odyssey? Did you find an article or link that showed this?
Re: best battery? [Re: ramman5600] #1234575
05/19/12 03:46 PM
05/19/12 03:46 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
napa legend
Re: best battery? [Re: ramman5600] #1234576
05/19/12 04:06 PM
05/19/12 04:06 PM
Locomotion Offline
Locomotion  Offline
Checking the specs between the same series batteries showed the same numbers weight, amps, etc. Cases are the same, just a different color. While it is possible there may be some differences, several other people on different forums observed the same thing.
Sears Platinum
Odyssey
Can't explain the listed 4 lbs difference. But I wouldn't call it a "deal breaker".
Re: best battery? [Re: Locomotion] #1234577
05/19/12 10:45 PM
05/19/12 10:45 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Thanks. Amazing that the same battery in basically a different color is $100 cheaper.
-C
Re: best battery? [Re: ramman5600] #1234578
05/21/12 12:38 AM
05/21/12 12:38 AM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
Car quest batterys are strong. I have over charged one to the point it was boiling over before took it in the next day to get it tested and nothing was wrong with it. The car quest batterys are made by east penn and they are real good batterys i believe the napa legend batterys are also made by east penn. If i couldnt get a car quest or a napa legend then my second choice would be an excide, had good luck with excides too. Stay away from the les swchwab batterys those are junk i used to work at schwab always warrantying batterys.
I hve never had good luck with the ever starts from wal mart or the interstate batterys ether.
Re: best battery? [Re: pjc360] #1234579
05/21/12 02:33 AM
05/21/12 02:33 AM
Akron, Ohio
VegasCharger Offline
Akron, Ohio
East Penn also makes AAA Auto Club batteries available through your AAA membership. I know this because I'm an installer. I have one in my Charger (group 34) and it does the job, 2 years going strong. Some AAA outfits use Interstate batteries I think in CA but here in NV its East Penn. Good Luck
