Re: Anyone use the Indy max block?
[Re: paul69cuda]
#1234133
05/15/12 10:33 PM
05/15/12 10:33 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Looking into alum blocks I heard something about cam bearings with Indy blocks but not sure if it was bs or not. Looking for guys that use them for real world experience.
I been told the Indy block doesnt have bushed lifter bores and still needs some other work done to it, I went with World aluminum block and it came with bushed lifter bores i havent got it yet as Muscle Motors is doing the short block for me.
[Re: rickraw]
#1234135
05/16/12 12:28 AM
05/16/12 12:28 AM
Posts: 4,648 aotearoa
rebel
aotearoa
only had to hone to final size & deck the block & tap all the threads to the bottom of the holes & it was all go. for safety i enlarged all the main oil feeds. now that my combo all works together i'm very happy with my purchase.
[Re: rebel]
#1234136
05/16/12 12:41 AM
05/16/12 12:41 AM
Posts: 903 Saskatchewan, Canada
cudabin
I had one and it was very poor casting quality... My latest motor I went with a Kieth Black alum block and it was great!! Ken Black is also much better to deal with. Go KB, and don't look back! Good luck, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: B G Racing]
#1234138
05/16/12 09:16 AM
05/16/12 09:16 AM
Posts: 2,938 A shed in England
Tig
A shed in England
KB here. Excellent product and great after sales service. We have had no probs with the plain aluminium lifter bores in 6 seasons, we never optioned lifter oiling either.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1234139
05/16/12 09:32 AM
05/16/12 09:32 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I use the Indy Maxx aluminum blocks no problems with them.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Tig]
#1234140
05/16/12 10:22 AM
05/16/12 10:22 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Same here.
[Re: rickseeman]
#1234144
05/16/12 01:19 PM
05/16/12 01:19 PM
MRMOPAR622
Sweet Home Alabama
I own 2 Indy Maxx aluminum blocks 1 Rb deck height the other is milled down to LD height.Both of mine and quite a few more I have seen have all been Hi Quality,I guess you can get a bad one in any after market block like someone in a above post stated. I have seen both dry & wet block KB blocks and they also appear to be Hi Quality blocks. They are beefed up more than the Indy blocks which if needed should be a +,but if the extra strength was not needed then due to the increase weight it would be a -.
[Re: MRMOPAR622]
#1234145
05/16/12 01:33 PM
05/16/12 01:33 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
Billy is that you in the photo? I think you forgot to shave today
[Re: Twin Turbo Mower]
#1234147
05/16/12 02:28 PM
05/16/12 02:28 PM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Bought my Indy around 2000. There was a water leak, porousity, which I fixed by drilling a hole, threading and installing a plug. Other than that, no problems so far. Have dynoed 1580 hp at 6100 rpm and now hopefully making more, so at least it doesn't blow up immediately at that point. I have also seen world blocks and KB's, actually building two KB's at the moment. I have no problem using any of them, each one has nice features that the others don't have. I would have no problem with any of them,unless very unlucky.
Plynouth VIP '67 TT IC EFI
[Re: HEMIFRED]
#1234149
05/16/12 05:31 PM
05/16/12 05:31 PM
MRMOPAR622
Sweet Home Alabama
Re: Anyone use the Indy max block? [Re: MRMOPAR570] #7208594 - Wed May 16 2012 12:33 PM Reply to this post Reply Reply to this post Quote Quote: I own 2 Indy Maxx aluminum blocks 1 Rb deck height the other is milled down to LD height.Both of mine and quite a few more I have seen have all been Hi Quality,I guess you can get a bad one in any after market block like someone in a above post stated. I have seen both dry & wet block KB blocks and they also appear to be Hi Quality blocks. They are beefed up more than the Indy blocks which if needed should be a +,but if the extra strength was not needed then due to the increase weight it would be a -. Billy is that you in the photo? I think you forgot to shave today That is me in the photo
[Re: paul69cuda]
#1234151
05/18/12 03:20 AM
05/18/12 03:20 AM
Posts: 345 iowa
wesw
iowa
i have a extra one for sale if you are looking. new still boxed up.
598 ci predator
