Steering Column rebuild, list... #1233652
05/15/12 10:53 AM
05/15/12 10:53 AM
MA
1968 Charger B5 Offline OP
MA
Is there any one place that sells an entire steering column rebuild kit? Say all the bearings, etc...?
1968 Dodge Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
Re: Steering Column rebuild, list... [Re: 1968 Charger B5] #1233653
05/15/12 11:03 AM
05/15/12 11:03 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
No, I pieced mine together from a few sites and dealerships. If it is, would be awesome.
Ryan
Re: Steering Column rebuild, list... [Re: Devil] #1233654
05/16/12 05:04 PM
05/16/12 05:04 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i think theres only 1 bearing,the upper one.
Re: Steering Column rebuild, list... [Re: cuda-sweden] #1233655
05/16/12 05:34 PM
05/16/12 05:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
actually, it depends on the year
1966 there is an upper only - lower is just rubber seal/flap
1967 there is a multipiece lower bearing along with the caged upper
1968-69 there is a caged lower encased in a plastic lower shell with the caged upper bearing
1970-71 there is a plastic lower bushing and a caged upper bearing
