Re: strange problem
[Re: MoparforLife]
#1233577
05/15/12 01:06 PM
05/15/12 01:06 PM
Posts: 406 California City, CA
dart440
California City, CA
I agree with MoparForLife, sounds like it is slightly lean off idle. Could be weak or late accelerator pump shot, or maybe you need to change metering rods or jet size slightly to eliminate the condition. His method to check will work to tell you if it's lean or not...
When you work on Spaceships for a living, how bad can a workday be?
Re: strange problem
[Re: Dodgem]
#1233579
05/15/12 02:30 PM
05/15/12 02:30 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
Yup.First thing came to mind was slight lean out. I read somewhere years ago that basically ALL aftermarket carbs OOTB are jetted and cal'd for SB chevy Acc pump setting may crutch it, but you probably need to do what the others say and mess with the metering rods.Timing may be OK the way it is, but if you read the threads lately, it all comes back to one thing at a time or you end up chasing your tail, and when you DO get it right, you may not know which of your adjustments actually fixed which problem. Case
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: strange problem
[Re: pjc360]
#1233584
05/16/12 01:43 AM
05/16/12 01:43 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Have you tried disconnecting the vacuum advance? Yes I run vacuum advance but I've seen MP distributors with rotor phasing errors bad enough that when the vacuum advance is adding timing the spark winds up intermittently hitting the wrong tower.... If disconnecting the vacuum cures the stutter check rotor phasing....
Re: strange problem
[Re: pjc360]
#1233590
05/16/12 04:13 AM
05/16/12 04:13 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
What is confusing me the most is this only happens while at a stand still driving down the road it does not do this. That alone should be able to tell if its ignition or carburetor. ut i just dont know cause i have never seen this kind of situation before.
If it doesn't do it while driving then what is the problem ? Why are you revving the piss out of the engine at a standstill in neutral ?
Re: strange problem
[Re: JohnRR]
#1233592
05/16/12 08:16 PM
05/16/12 08:16 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
John - that is a dang good question. To bad it wasn't mentioned earlier. I hate chasing goasts.
Re: strange problem
[Re: pjc360]
#1233596
05/17/12 11:59 PM
05/17/12 11:59 PM
Posts: 905 SD
zrxkawboy
SD
Kinda hard to diagnose problems over the internet, but it just sounded like an ignition advance issue. Glad you're getting it sorted out.
So, do you mean the reluctor and pickup are physically hitting each other? Maybe I'm misunderstanding you. There should be about 0.008" gap.
It's Swifty! Swifty, you toad sucker!
