340 w-2 heads OPEN CHAMBER #1233565
05/15/12 01:27 AM
05/15/12 01:27 AM
louisville,kentucky
moparmangolf Offline OP
louisville,kentucky
I have a W2 open chamber head, head number P4532693 does anyone know what the CC of this head is and is this a good race head for a 12:1 dome piston i have 396 stroke crank .30 over which makes 412 cubic inches I need to know will this head work with a dome piston were ported the head and flowed them on an indy cylinder bench and it flowed .305 and some change $ my buddy told me that with this head and the dome piston will make to much compression and will be blowing gaskets does anyone know if this is right or wrong any help would be great thank you very much....
Re: 340 w-2 heads OPEN CHAMBER [Re: moparmangolf] #1233566
05/15/12 06:55 AM
05/15/12 06:55 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You will have to check them, they all vary a little. I had read all the info out there on them trying to figure out what mine were, and ended up CC'ing them. Glad I did.
Re: 340 w-2 heads OPEN CHAMBER [Re: moparmangolf] #1233567
05/16/12 11:37 PM
05/16/12 11:37 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
The chamber on my W-2s was within 2 cc of a std 340 head. I got mine new and they came in at 70 cc. I think spec is supposed to be same as the std head @ 68cc.
Re: 340 w-2 heads OPEN CHAMBER [Re: moparmangolf] #1233568
05/16/12 11:46 PM
05/16/12 11:46 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Well with 12:1 you should use head studs and composite gaskets... imo. Stock o/c W2's should spec out somewhere around 70cc. Personally I would have gone with closed chamber and D-dish pistons.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 340 w-2 heads OPEN CHAMBER [Re: DARTH V8Я] #1233569
05/17/12 03:15 PM
05/17/12 03:15 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
After chamber clean=up mine were 72cc. My CR is 11.2 with a flat top piston @ 0 deck hght.
