Crimper for 69 b-body harness connectors #1233482
05/14/12 07:54 PM
05/14/12 07:54 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
I'm fixing some wiring issues on the RR and bought these connectors.
What crimper would you use or where would I find one that will correctly crimp these? Don't want to drive all over town looking, until I have to.
Thanks!
dstryr, since 1986.
Re: Crimper for 69 b-body harness connectors [Re: dstryr] #1233483
05/14/12 09:28 PM
05/14/12 09:28 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
I think mine are klien tools 1005
Re: Crimper for 69 b-body harness connectors [Re: dstryr] #1233484
05/14/12 09:36 PM
05/14/12 09:36 PM
CT
1932chrysler Offline
CT
American autowire sells the crimpers
here is a video how to use them
http://www.youtube.com/watch?v=8u_EkMsioMY
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: Crimper for 69 b-body harness connectors [Re: dstryr] #1233485
05/15/12 11:12 AM
05/15/12 11:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is called a flag terminal, you should be able to get a tool to crimp them at a hardware store with a well stocked tool section.
Re: Crimper for 69 b-body harness connectors [Re: crowbait] #1233486
05/15/12 11:23 AM
05/15/12 11:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That tool may do them but it's not really the correct size for the smaller wire gauges .
I bought the MSD spark plug wire crimp tool and I was able to buy a die set to do the flag terminals also ...
Re: Crimper for 69 b-body harness connectors [Re: JohnRR] #1233487
05/15/12 12:29 PM
05/15/12 12:29 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Try Radio Shack if you can't find it at a hardware store
When you work on Spaceships for a living, how bad can a workday be?
Re: Crimper for 69 b-body harness connectors [Re: dart440] #1233488
05/15/12 11:13 PM
05/15/12 11:13 PM
Wendy, I'm home.
dstryr Offline OP
dstryr  Offline OP
Wendy, I'm home.
Thanks for the help. Looks like the 500649 tool is around $100 with good quality equivalents in the same range. Hope a parts store has one as a loaner.
dstryr, since 1986.
Re: Crimper for 69 b-body harness connectors [Re: dstryr] #1233489
05/16/12 03:41 PM
05/16/12 03:41 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
You need a crimper for a Delphi/Packard 56 terminal
NS1AAR
Re: Crimper for 69 b-body harness connectors [Re: ns1aar] #1233490
05/16/12 04:59 PM
05/16/12 04:59 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I use the 1006, haven't tried the 1005 on the bare connectors.
Re: Crimper for 69 b-body harness connectors [Re: Snoopy] #1233491
05/16/12 05:32 PM
05/16/12 05:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1006 would be the tool to get as it has the 2 sizes that would be required .
Re: Crimper for 69 b-body harness connectors [Re: ns1aar] #1233492
05/16/12 06:19 PM
05/16/12 06:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This one.You can get it from NAPA for about $35.
