Re: Mild 383 build with eddy heads!
[Re: 383ramd150]
#1232579
05/13/12 11:06 AM
05/13/12 11:06 AM
Posts: 5,949 British Columbia
chrisf
British Columbia
I think i just came up with one so let me know what you think!My 318 is getting xe268 cam so i am sticking with Comp Cams.383 bored .030 over,kb400 pistons,84cc eddy heads with 10.1 comp,performer rpm intake,mighty demon 750,stock crank and eagle rods.Now for cam,either XE274 with 488/491 lift with stock rockers or XE275HL with 525/525 lift with roller rockers.727 with 3000 stall and 4.10 gears which is getting ready to go in truck!But still open to suggestions.
i have pretty much this same set up in my 78. except a lunati 302 cam, source heads and a 670 street avenger, 3.21's. works well, good power
[Re: mark7171]
#1232582
05/13/12 11:50 AM
05/13/12 11:50 AM
Posts: 75,102 A Banana Republic near you.
JohnRR
Mopar has the biggest lobes that provide fastest ramping already. It has been there all along.
Maybe if you buy an MP cams , most cams were/are ground on .842 chevy lobes .
[Re: mark7171]
#1232584
05/13/12 02:04 PM
05/13/12 02:04 PM
Posts: 32 LaFollette TN 37766
383ramd150
LaFollette TN 37766
yeah it is a bare block.Which one 383/431 or muscle motors 383/450!Definately need it for torque!But Ive got 383 crank,just nothing else.
