Page 2 of 3 1 2 3
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232504
05/16/12 07:19 PM
05/16/12 07:19 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232505
05/16/12 07:19 PM
05/16/12 07:19 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
nvm just found it
http://www.hughesengines.com/Index/produ...mp;partid=25200
I wonder how hard it would be to make that
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232506
05/16/12 08:36 PM
05/16/12 08:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
these few numbers aren't exactly making me feel confident lol.
Thumper, what collar are you talking about that prevents the gear from "riding up"?
Mine`s plastic that I cut to fit w/just a slight bit of pressure on it when tight now that I have the torrington set up...........
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232507
05/16/12 08:44 PM
05/16/12 08:44 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
You should be able to fab one or buy something at a industrial shop.
As for your bronze gear from MP I paid around 75 dollars for one from a dealer. OVER HERE.
Re: SB bronze distributor gear- how to install, longevity?? [Re: MattW] #1232508
05/16/12 10:37 PM
05/16/12 10:37 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Maybe something like this. I make these that actually fit the shaft...not .500 inch ones you buy at the hardware store.
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232509
05/17/12 07:50 AM
05/17/12 07:50 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Distributor / oil pump shaft Torrington Bearing
Re: SB bronze distributor gear- how to install, longevity?? [Re: DusterW2] #1232510
05/17/12 07:51 AM
05/17/12 07:51 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Pic 2
Re: SB bronze distributor gear- how to install, longevity?? [Re: DusterW2] #1232511
05/17/12 07:52 AM
05/17/12 07:52 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Pic 3
Re: SB bronze distributor gear- how to install, longevity?? [Re: DusterW2] #1232512
05/17/12 09:01 AM
05/17/12 09:01 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Thats nice Dusterw2. Someone need to sell those complete like that.
Re: SB bronze distributor gear- how to install, longevity?? [Re: 70VcodeCoronetRT] #1232513
05/17/12 09:32 AM
05/17/12 09:32 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Agreed! What is the part number for that bearing?
Re: SB bronze distributor gear- how to install, longevity?? [Re: MattW] #1232514
05/17/12 09:35 AM
05/17/12 09:35 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I ordered the gear from Summit the other day since I had to get some other stuff from them...50 opposed to the 70 when I called the dealer (you were spot on)
As for the collar, I think im going to try to fab something up just because Im really trying to get this thing together and don't want to wait for another part to arrive in the mail
Just have to measure the distributor to see what the ID of the collar should be
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232515
05/17/12 09:45 AM
05/17/12 09:45 AM
Moparnut426 Offline
Moparnut426  Offline
You can also measure the distance from where the top of the drive gear, and the bottom of the distributor and make a plastic shaft that goes over the distributor shaft and holds the gear down when the distributor is in. Then you wouldnt need to tie it to the distributor shaft, it would just float on the distributor.
Re: SB bronze distributor gear- how to install, longevity?? [Re: mshred] #1232516
05/17/12 12:44 PM
05/17/12 12:44 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Shaft Collars - Local Grainger Dealer
http://www.grainger.com/Grainger/shaft-c.../ecatalog/N-clj
Needle Thrust Bearings -
http://www.nationalprecision.com/needle-bearings/thrust.html
For a 0.500" shaft, Torrington needle thrust
Bearing NTA 815 (1)
Washer TRA 815 (2)
Verify dimensions for bearing and washer on pump shaft and gear, machine to fit.
Re: SB bronze distributor gear- how to install, longevity?? [Re: DusterW2] #1232517
05/17/12 02:17 PM
05/17/12 02:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s exactly what I have and my timing varies less than 1 degree.......
Re: SB bronze distributor gear- how to install, longevity?? [Re: Thumperdart] #1232518
05/17/12 04:14 PM
05/17/12 04:14 PM
The Great White North
RAMM Offline
RAMM  Offline
Why would you want to put another source of teeny tiny steel thingys in your engine? The collar I understand and like--the torrington bearing-not so much. Oh and to answer your question MShred---Yes your bronze gear is going to wear--they are a consumable. Why did you get a hydro roller on a billet shaft? They work just as well on a cast core and you wouldn't have to run the bronze gear to boot. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: SB bronze distributor gear- how to install, longevity?? [Re: RAMM] #1232519
05/17/12 04:31 PM
05/17/12 04:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Because it`s 2012 and things get BETTER sometimes plus the needles are samwitched between the washers unlike the set screw for the collar which is swinging in the wind...........
Re: SB bronze distributor gear- how to install, longevity?? [Re: Thumperdart] #1232520
05/17/12 04:55 PM
05/17/12 04:55 PM
Moparnut426 Offline
Moparnut426  Offline
Mine isnt swinging in the wind, Im a little over cautious and I put a hose clamp around mine so the screw wouldnt come out in the engine.
Re: SB bronze distributor gear- how to install, longevity?? [Re: RAMM] #1232521
05/17/12 05:14 PM
05/17/12 05:14 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Comp sent it to me on a Billet core after an issue I had with tracking marks on the lobes of a cast core...I never requested the billet core, they just sent it that way...kinda wishing they didnt now
Re: SB bronze distributor gear- how to install, longevity?? [Re: Moparnut426] #1232522
05/17/12 07:43 PM
05/17/12 07:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So now you have a component holding a spinning object that wasn`t designed for anythingg but clamping hoses.................
Re: SB bronze distributor gear- how to install, longevity?? [Re: Thumperdart] #1232523
05/17/12 11:15 PM
05/17/12 11:15 PM
Moparnut426 Offline
Moparnut426  Offline
YEP, the same object that is used in dealer applications to balance driveshafts. Ive had to do that after talking with a chrysler tech assistance dude on a dodge durango.
They work fine that way,
Page 2 of 3 1 2 3
