71 roadrunner 1/4 window install.. any trick? #1231970
05/11/12 11:36 PM
05/11/12 11:36 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Im going to be putting in my 1/4 windows in my 71 roadrunner and was wondering if theres much a trick for it? I had a heckuva time taking them out and putting them in the way I took them out, I would certainly scratch up the paint. any help is appreciated.
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 roadrunner 1/4 window install.. any trick? [Re: mopars_1] #1231971
05/15/12 11:30 AM
05/15/12 11:30 AM
fiddlerfingers Offline
Take the long metal track that the window rides on out and mount the window on it first. Then you can slide the whole thing back in the opening. They are tricky so make sure you tape up all painted areas around the openoing to prevent chips/scratches. I just did mine on a 71 RR and I followed what the chassis manuel stated, worked great...Good Luck
Re: 71 roadrunner 1/4 window install.. any trick? [Re: fiddlerfingers] #1231972
05/15/12 12:17 PM
05/15/12 12:17 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I guess I never thought to looked in the manual.. haha. thanks!
1937 Plymouth PT50
