Help ID my engine #1231029
05/10/12 01:42 PM
05/10/12 01:42 PM
louisville ky
67gtxclone Offline OP
louisville ky
my numbers on the valve cover are TNXE6257710267 is this a car engine or truck and is it a 2007 I purchased it from a guy who bought it as a crate engine but he wasnt sure what year it was i cant find any info thanks for any help
Re: Help ID my engine [Re: 67gtxclone] #1231030
05/10/12 03:49 PM
05/10/12 03:49 PM
louisville ky
louisville ky
anyone?
Re: Help ID my engine [Re: 67gtxclone] #1231031
05/10/12 04:57 PM
05/10/12 04:57 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
post up a picture of it! no idea what those numbers are that you posted
**Photobucket sucks**
Re: Help ID my engine [Re: 70Cuda383] #1231032
05/10/12 05:08 PM
05/10/12 05:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
numbers on the valve covers meen nothing. Check to see if there is small numbers stamped into the face of the block just below where the head bolts on the drivers side of the engine.
AS stated We like pics !!!.
I am truckless..
Re: Help ID my engine [Re: 67gtxclone] #1231033
05/10/12 10:39 PM
05/10/12 10:39 PM
Where is the distributor? Is it a BB or SB?
Re: Help ID my engine [Re: Cab_Burge] #1231034
05/10/12 10:48 PM
05/10/12 10:48 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
whelp, using basic logic, in '07 the only v-8 available in both cars & trucks is the 5.7. if that's the case, is the alt. mount high(truck) or low(car)?????
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Help ID my engine [Re: Flite_727] #1231035
05/11/12 12:56 PM
05/11/12 12:56 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
by using the same basic logic you can read that its a crate engine, so it could be anything.
