correct weight oil and when to use synthetic #123055
09/19/08 09:57 AM
09/19/08 09:57 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i have a fresh 408 indy headed sb with solid roller cam. used primarily on the street. what weight oil should be used? it has .002" main and rod bearing clearance, but the t&d rockers dump alot of oil with the grooved cam jounals and full groove mains. also, when can synthetic oil be used? i'm concerned with rings seating well.
Re: correct weight oil and when to use synthetic [Re: mopar dave] #123056
09/19/08 10:24 AM
09/19/08 10:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would use a 15/40 or 20/50 with a good filter, i would switch at about 2k miles to syn.
Re: correct weight oil and when to use synthetic [Re: mopar dave] #123057
09/19/08 12:14 PM
09/19/08 12:14 PM
After breakin you can switch & use the lightest weight of oil that will maintain "adequate" pressure.
Re: correct weight oil and when to use synthetic [Re: RapidRobert] #123058
09/19/08 03:04 PM
09/19/08 03:04 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Read this Break in secrets.
Then use a 10W-40 or 15W-40 synthetic oil and you should be good to go.
Re: correct weight oil and when to use synthetic [Re: RapidRobert] #123059
09/19/08 03:23 PM
09/19/08 03:23 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I agree. I had to drop a weight in oil to help get my pressure down. I run 30-40 psi at idle and
60-70 psi @ 25oo rpm hot. Was higher than that with heavier oil!
Re: correct weight oil and when to use synthetic [Re: Spike] #123060
09/19/08 03:29 PM
09/19/08 03:29 PM
Re: correct weight oil and when to use synthetic [Re: RapidRobert] #123061
09/23/08 10:16 AM
09/23/08 10:16 AM
Mt Morris Michigan
Mt Morris Michigan
thanks robert. interesting read. it may be to late for proper break-in. i have 160 miles on it now with some hard acceleration and decellaration, mostly cruising with varying throttle positions.
Re: correct weight oil and when to use synthetic [Re: mopar dave] #123062
09/23/08 05:03 PM
09/23/08 05:03 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Royal Purple 10-40 per my builder after 2500. Did a few WOT's before 2500. All is well after 20 thousand street miles. 440.
