Page 9 of 10 1 2 7 8 9 10
Re: Should you be able to trust your engine builder? [Re: fishy340] #1230325
05/14/12 04:23 PM
05/14/12 04:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
im damn sure sure the effort for who ever you are is the same!
Obviously this is NOT the case here...Just saying if it were there would be no post on the subject!
Re: Should you be able to trust your engine builder? [Re: Al_Alguire] #1230326
05/14/12 05:32 PM
05/14/12 05:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Never having had the reputation as the bashfull sort, and actually kind of proud of myself for calling a spade a spade, i will quickly relate an issue i had with SDSS.
Few years back i had a set of w5 heads ported by sdss.
I had them sent to Best Machine and a whole engine put together( which i might add i never had any issues with, beat on it for years, and the current owner after a Best freshen up/upgrade continues to do..to this day.
I got a call from Chuck at Best and drove down to Detroit to see for myself his concern with the heads. 3 or 4 of the spring pockets were so thin that Chuck easily took a pencil and pushed holes all the way through them....not good when planning to run a roller with some associated spring pressure.
Chuck repaired them, and thought we should pressure test them...they were sprinklers, again, were fixed and made to be usuable.
I was quite surprised they were sent out of SDSS in that way, had someone not looked them over good...well i shudder to think..
Just a couple of issues that come to mind from my own personal first hand experience.
To SdSS credit, that was i believe the first set the shop had done, but still sending that junk out was unpardonable.
Having had several excellent experiences with Best Machine, and earlier along, Hensley, i would have no problems recommending either shop, particularly Best Machine.
Owning a business myself, i am well used to never hearing when you we do things great( occasional pleasant surprise though), pretty much always hearing when you dont.
This above fact leads me to believe most here that think not airing expensive/costly screwup issues in public isnt right, probably dont have a business where the buck stops with them.
You choose to enter the shark tank, you can get bit, its just flat how things work.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Should you be able to trust your engine builder? [Re: dartman366] #1230327
05/14/12 05:33 PM
05/14/12 05:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
After 1 season and had to repair 4 guides in 1 head(cannot remember how many in the other) because they decided to slide towards the valve head because they were not machined correctly,,are you kidding me!,that was not a parts failure, that was in the machining, you do not want to know what my present machinist/builder had to say about that mess that he ended up fixing,,
Are you sure that wasnt the fault of the low quality mopar performance head you used? They always seemed to have machining issues and bad metallugy from the get go..You dont need to remove valve guides to do most heads... unless you got them without guides in them.
Re: Should you be able to trust your engine builder? [Re: B3422W5] #1230328
05/14/12 05:59 PM
05/14/12 05:59 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
They almost got away with another F up its funny how supposed engine builder can get away with this crap, I also own a business and surley could not get away with it. I would be sued. I have voiced my opion many times on this shop.
Re: Should you be able to trust your engine builder? [Re: mokid] #1230329
05/14/12 09:14 PM
05/14/12 09:14 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
I'll make my experience short and sweet...
402 stroker FAST motor. Sent to Ryan to have a freshen up and be switched to a 71 Duster configuration (Different intake, and exhaust manifold), Put the car together and it was a pig, Low 12's is all it would do. Talked to Ryan immediatly, he told me to change everything else. After changing everything under the sun (intakes, carbs, ignition systems, exhaust systems, etc.) and spending 6months and at least 15 track sessions, found he never degree'd the cam. He threw it in at 101.5 instead of 108.5. Said he must have bumped the tdc pointer. Offered a free dyno session.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Should you be able to trust your engine builder? [Re: F1Scamp] #1230330
05/14/12 09:33 PM
05/14/12 09:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Well I have had two shady dell motors, and have been nothing but happy with them. First was a 422 indy 360-1 motor that went 9.90s in my car and the current one that has been 9.55. Thats a 422 w-9 motor.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Should you be able to trust your engine builder? [Re: 1967dartgt] #1230331
05/14/12 10:44 PM
05/14/12 10:44 PM
BPE Offline
BPE  Offline
I Just got off the phone with a guy that I was trying to help get some W5's taken care of and he told me a recent story about SDSS. From what I was told Ryan somehow ruined his x block by running the cutter into the back of it. Since I don't want people to think I'm some sort of RyanJ hater, I'm about to tell you the rest of the story. According to what this guy told me he said Ryan is going to get him a resto 340 block and do all of the machining, including bushing the lifter bores free of charge. So maybe this post has helped in some way. This is how things should be done, so good for you Ryan.
Rod
Re: Should you be able to trust your engine builder? [Re: 408strokerdart] #1230332
05/14/12 11:00 PM
05/14/12 11:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i have read all ur post. why was this RACE ENGINE just run in, instead of being dynoed? who's decision was that?? was $$$ a factor?? problem probably would have showed up on dyno. ryan did my heads on my sb, couldn't be happier. sucks u had problems.
Re: Should you be able to trust your engine builder? [Re: fishy340] #1230333
05/15/12 12:30 AM
05/15/12 12:30 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
2 issues you mention great shop is when issues arise,i'm pretty sure if this issue was done by phone or email rj probably would have made good,or said its not my fault,,we will never know,,,as far as to the issue of being close or far away,thats just bs Al...take a look in ryans shop for orders on things as far away as australia.im damn sure sure the effort for who ever you are is the same!
There are some unhappy customers down this way also, but quite frankly, I have seen alot of junk come out of the US.
I am of the opinion that if you are not 100% willing to stand by every part in an engine, new or s/h, then don't do the job, it's not worth the headache.
Alan Jones
Re: Should you be able to trust your engine builder? [Re: rickraw] #1230334
05/15/12 12:40 AM
05/15/12 12:40 AM
Out West
408strokerdart Offline OP
Out West
Engine was running over my budget and time wasn't going to allow a dyno session as I drove from Texas to Pittsburgh Raceway Park to take delivery of it.
Re: Should you be able to trust your engine builder? [Re: Hot 340] #1230335
05/15/12 02:18 AM
05/15/12 02:18 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
No it wasn't the low quality Mopar Performance head's that I used, they came with 3/8" stem size guides and he replaced them with 11/32" guides,so Mopar had nothing to do with it,,,and the rest is history.
Re: Should you be able to trust your engine builder? [Re: 408strokerdart] #1230336
05/15/12 03:29 AM
05/15/12 03:29 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
Honestly i would never trust an engine builder unless they were brand specific, ie take a mopar to a mopar guy, a ford to a ford man, chevy to a chevy fanatic. I learned my lesson after taking my 440 to a machine shop where the owner and workers were all chevy fans, they made offhanded comments about "that ugly ole mopar block" and did a really piss poor job of vating the block and crank, i ended up having to run gun cleaners through the journals to get all the trash out they left behind, i assemble my own engines so i hate to think how bad it would have been if i were to have had them assemble the 440
Re: Should you be able to trust your engine builder? [Re: racer_amx] #1230337
05/15/12 03:48 AM
05/15/12 03:48 AM
Finland
mafo Offline
mafo  Offline
Finland
I assemble my own engines, so I have to trust myself but I often check and double check my own work
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Should you be able to trust your engine builder? [Re: mafo] #1230338
05/15/12 05:26 AM
05/15/12 05:26 AM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
Most of the small block guys on here are the ones who made him out to be the "small block guru" but he was learning as he went with all your stuff. Pays to do your research.
Is he trade qualified or just picked it up?
Re: Should you be able to trust your engine builder? [Re: vc360] #1230339
05/15/12 05:56 AM
05/15/12 05:56 AM
LA360 Offline
LA360  Offline
A history major at College I believe
Alan Jones
Re: Should you be able to trust your engine builder? [Re: vc360] #1230340
05/15/12 07:22 AM
05/15/12 07:22 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
X2! Nothing compares to a trained, skilled tradesman who has went to school to learn and worked years at his craft! Just because someone can memorize/spout off part numbers for mopar performance parts does not make them qualified to machine/assemble engines. I personally have even less faith in the "gurus" who write books. While they are entertaining and sometimes informative/helpful reading, it has been my experience that the real engine builders who know how to make HP don't/won't tell you anything as they have spent years/decades learning what works and what doesn't. With the advancement of technology I also don't see how anyone could/would be happy with a 400 plus cubic inch W-9 headed "Race motor" that only runs mid to high 9's, maybe high 8's on spray, W-5 headed motors were doing that 15+ years ago...
Re: Should you be able to trust your engine builder? [Re: stevet340] #1230341
05/15/12 08:55 AM
05/15/12 08:55 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: Should you be able to trust your engine builder? [Re: 1967dartgt] #1230342
05/15/12 09:35 AM
05/15/12 09:35 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
This post has for the most part turned into a witch hunt, Whats next...Did the builder kick a dog in 1995??? In any business your only as good as how you resolve problems.... The OP did not give the builder that chance.... With that said do we want to kill any other builders that have a failed part or engine? This could become a very long post
Re: Should you be able to trust your engine builder? [Re: emarine01] #1230343
05/15/12 09:58 AM
05/15/12 09:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a engine blow up in its first 1/8 mile pass...
that wasnt the builders fault ... that one had a lifter
tie bar fail and cost me $3500 to fix... I also had
a pro builder build my very first race engine and it
never made it down the track... that one was the builders
fault... a rod nut was laying in the pan... since that
time I build my own junk
Re: Should you be able to trust your engine builder? [Re: MR_P_BODY] #1230344
05/15/12 01:15 PM
05/15/12 01:15 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Well most who have posted on this tread have at some point in the past. Lamented how there is not much techno exchange here anymore. As most the the builders have left. Curtis Boggs, Fast68Plymouth, DTHEMI to name a few no longer post. I'm sure Ryan will be added to the list. I learned alot from those guys.
But as I recall in the Bible it says if you have a problem with someone. Go to them and try and resolve it first. Before bringing it to the community.
I understand Brian didn't want to ship his parts or trust RJ. That was his decision to make. But I think he nothing to loose except his effort. To at least give RJ a chance to offer some sort of resolution.
I have lost respect for some in this post. I'm sure nobody cares anyway and I'm fine with that. But at the end of the day we are all only as good as our word. Jim
