8.75 sure grip clutch disc material #1229998
05/08/12 10:59 PM
05/08/12 10:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
hi!
I was about to rebuild my 8,75 sure grip and turns out one of the discs is missing in my rebuild kit.
Its one of the flat cross shaped discs.
I was thinking about fabbing one myself.
What kind of material should I use?
thanks
Domingo
Re: 8.75 sure grip clutch disc material [Re: domingo] #1229999
05/09/12 01:52 PM
05/09/12 01:52 PM
dogdays Offline
dogdays  Offline
The 8.75 clutch type Sure Grip is a Spicer Powr Lock. Dana-Spicer is all around the world and they may even have distributors in your country. You may be able to get something from a local source.
R.
Re: 8.75 sure grip clutch disc material [Re: dogdays] #1230000
05/10/12 08:56 PM
05/10/12 08:56 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I wont be able to get it locally, and if I were, i bet they will have to import the part....i can import it myself...would be cheaper and faster...
however, I bought the complete kit and it seems that either at customs or somplace one of the discs fell out of the box.
I can sure make the missing disc myself since it is one of the flat ones with no spline indentations. However, I would like to know what material should I use to fab it.
Regular steel plate will work (not mild steel)? Do I have to harden it?
Re: 8.75 sure grip clutch disc material [Re: domingo] #1230001
05/10/12 11:48 PM
05/10/12 11:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I would use (hardened) T1 steel plate.
Re: 8.75 sure grip clutch disc material [Re: DoctorDiff] #1230002
05/11/12 12:00 AM
05/11/12 12:00 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
cool! Thanks for the info!!!
Re: 8.75 sure grip clutch disc material [Re: domingo] #1230003
05/12/12 08:26 AM
05/12/12 08:26 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have an extra flat external tanged disc if you need that one.
Mopar to the bone!!!
Re: 8.75 sure grip clutch disc material [Re: 72Swinger] #1230004
05/16/12 05:15 PM
05/16/12 05:15 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
This is the one that I need.
It's the thinnest gauge one of the hole pack (there are 2 of these in the kit, i am missing one). Its flat.
Is this the one u got??
Re: 8.75 sure grip clutch disc material [Re: domingo] #1230005
05/16/12 05:42 PM
05/16/12 05:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Domingo is that a new one or your OLD one in that picture ? If it's the old one the thin one is usually against the end of the stack and one side is against the case and sees no wear because it is keyed to the case , just flip it over ...
Re: 8.75 sure grip clutch disc material [Re: JohnRR] #1230006
05/16/12 06:11 PM
05/16/12 06:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This is what I have,it was an extra in my Mopar kit. I ship it to ya for 15 millione dollas!
Re: 8.75 sure grip clutch disc material [Re: 72Swinger] #1230007
05/16/12 06:33 PM
05/16/12 06:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
15 millione???
You are crazy!
If you got an extra one, and I got mine minus one....
then I bet thats mine!!! LOL
What thickness is it? Can you measure it???
Thanks!
Re: 8.75 sure grip clutch disc material [Re: domingo] #1230008
05/16/12 06:47 PM
05/16/12 06:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
.095
Re: 8.75 sure grip clutch disc material [Re: 72Swinger] #1230009
05/16/12 07:15 PM
05/16/12 07:15 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
awww
I need the thinner one which is about half as thick as that one and it is flat.
Re: 8.75 sure grip clutch disc material [Re: JohnRR] #1230010
05/17/12 12:51 AM
05/17/12 12:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Buelleur ... anyone ????
Re: 8.75 sure grip clutch disc material [Re: JohnRR] #1230011
05/17/12 11:57 AM
05/17/12 11:57 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Oh I didnt see your post.....
Well, I thought about doing that, But I can see the old ones are a bit worn to the point where they are somewhat thinner than the ones that came in the kit???? Thats what I decided against using them.
Re: 8.75 sure grip clutch disc material [Re: domingo] #1230012
05/17/12 12:16 PM
05/17/12 12:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the one in the picture above is the one you have it doesn't appear to be that worn ?
You do realize that there are 2 THINNER plates than the rest and those are the ones at the ends of the case?
I bought a kit , can't remember if it was MP or spicer, but it didn't come with the thin plates. I just flipped the 2 thin ones over, the only wear is in the center but I did lap them to make sure there weren't any high spots.
Considering where you live and the cost of shipping it something to look at.
Re: 8.75 sure grip clutch disc material [Re: JohnRR] #1230013
05/17/12 08:42 PM
05/17/12 08:42 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Yes, you are right...
I will take the best one of the 2 I have and just flip it over and lap it to make sure its flat.
Thanks!
