Re: Got our late 5.7 Hemi heads today!
[Re: MattW]
#1229955
06/06/12 07:37 AM
06/06/12 07:37 AM
Posts: 2,826 NY usa
540challenger
NY usa
Well I just got my 6.4 heads in the mail today
http://s1265.photobucket.com/albums/jj501/540Challenger/GenIII%20Hemi%20build/
My Alum. block should be here tomorrow i will have pictures up tomorrow
Which block did you get . Same place as the heads? Will be keeping an eye on you. Lol
The block i got through jegs. Since the block and heads are going to sit for at least a year while i gather funds to finsh the build. Since i tapped out my car fund between the hemi parts and Vet's bills
4500 cost for the block
1300 for the heads
2000 for the Vet bills b/c my 5 pound dog ate Chocolate so there goes the rotating assemble money
Nice had a 145 lbs rotty that ate a big green caterpillar. Stupid thing almost died. $$$$$$$ What block did you get? I think the one that is bored to 4.114 is the better one because if the amount of rebuilds you can get. ![](/ubbthreads/images/graemlins/shruggy.gif) Thx for the info.
Thats the one i got P5153898 4.114 semi-finshed bore and max bore at 4.185
[Re: MattW]
#1229957
06/07/12 08:36 AM
06/07/12 08:36 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
No port volumes as of yet. Ahhhh a 6.4 deal would be very nice. I would love to work with the aluminum block too. I'm so buried here at work who know's when I'll have time to get to the Hemi builds. I'm having some difficulty keeping up.
On a different note...I hope to be building a stroker 6.1 for my Duster by the end of the year so let's keep this going!!
Brian I think their is only 3 ways to make the Apache head work. Force induction, spinning.it to the moon in small CID form or large cubes. The second one I'm concern about possible oiling issues. The last ,and this is my avenues, is using the 4.25 crank. Apparently BES had to sink the valve .070 to make this work. ![](/ubbthreads/images/graemlins/Twocents.gif)
I could be totally wrong in saying this so don't take it personal. I don't think you need any expertise to port this heads. The port is a straight shot at the valve. No short turn to worry about.
IDK, a stock 392 works pretty well with them....granted they have variable valve timing....
I remember a long time ago, Dulcich did a stock stroke 440 using some big indy heads (can't remember if they were SR's or 440-1) that one would think would be waaaay too big for stock cubes, with a short, fast duration cam (IIRC comp XE275HL with either 1.6 or 1.7 rockers), and other than valtrain stability issues at high RPM caused by the hydraulic lifter, the engine was very responsive, and a monster both in HP and torque...
[Re: patrick]
#1229958
06/07/12 01:21 PM
06/07/12 01:21 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
A big Wedge head is a bit different than a big Hemi head! Everyone know's 426 Hemi's don't make any low speed power...it's all up top.
I don't think a 4.25 stroke is the best thing for most applications for me anyway. I like an engine that has some poop up top. I mean, isn't this what makes the Hemi Famous?? I like the 3.79 and 3.90 strokes, and I think 8000rpm is plenty to make most bracket guys happy. That's where we will be consentrating our efforts. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1229959
06/07/12 02:05 PM
06/07/12 02:05 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
when will we get some ported flow numbers?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1229961
06/07/12 04:42 PM
06/07/12 04:42 PM
patrick
Grand Haven, MI
yes and no...you get some inherent tumble and swirl induced by the wedge head's valves proximity to the cylinder wall, as well as increased shrouding that you won't get with a hemi or pentroof (closer to what the genIII is)....but overall intke tract length, port volume, cross section, and valve timing/action I bet have a bigger influence in low speed power than valve configuration. take a similar displacement hemi and wedge, with similar port volume/cross section built similarly, I bet their power curves will track pretty closely....
here's the dyno results of Dulcich's "mild manner mauler" which is a .030 over, stock stroke 440 with 295CC indy EZ heads, comp XE275HL with 1.7 rockers, and starts out with an indy dual plane intake....
http://www.moparmusclemagazine.com/projectbuild/mopp_0510_440_engine_dyno_test/dyno_results.html
with the indy 2 plane intake, those huge heads are making peak torque at 3500 RPM, while still making 96% of peak torque from 3100 RPM to 5500 RPM, where he got into instability issues trying to run a hydraulic lifter with an XEHL cam AND 1.7 rockers...runs 3 and 4 switch to a single plane intake, and that one change moved the torque peak up to 5000 RPM, but we only see about 85% of peak torque at 3100 RPM....
here's the same motor, but a switch to a small solid roller (242@.050)
http://www.moparmusclemagazine.com/techa...no_results.html
interesting how the peak torque with the dual plane intake jumped up to basically a plateau from 4500-5500 RPM, but it's still making 90% of peak torque from 3000 RPM to 6500, and with a switch to a single plane, peak torque jumped up to ~5000 RPM, but it's only making 81% at 3000 RPM...
[Re: patrick]
#1229962
06/07/12 11:21 PM
06/07/12 11:21 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Now go find a Hemi that somebody did those things to and you'll see what I mean.
Brian Hafliger
#1229967
06/26/12 07:58 PM
06/26/12 07:58 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
How bout this for a combo. production 6.4 short block for 2200. early 5.7 heads that should give you a 9.7 compression add cam headers dragpack intake and you have over 500 hp. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: mshred]
#1229971
06/27/12 06:13 PM
06/27/12 06:13 PM
MattW
Ontario Canada
Are 6.4's forged components in the bottom end? What is the cubic inch on these engines? Thats a pretty screaming deal
Yes but the rods are powder crack type floating pin. 6.4 cid is 392.
[Re: AlexP]
#1229974
06/27/12 07:20 PM
06/27/12 07:20 PM
Posts: 945 La Vernia, Texas
Pat7272
La Vernia, Texas
We picked up 30rwhp and 28rwtq from an almost bone stock 392 with only ported 6.4 heads.
6.4 is a good number for hemi's, with the apaches or nor.
Are the 6.4 heads significantly better than the 6.1? How about the Apache?
