Re: tire pressure, per tire rating or vehicle sticker??
[Re: Captain Flapjack]
#1229728
05/08/12 08:21 PM
05/08/12 08:21 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
depends.
I monitor tread wear and adjust air pressure accordingly. the max pressure on the sidewall is for when the vehicle is fully loaded.
I typically run 35psi on all vehicles. if I'm going to pull a heavy load in the truck, I air them up to 45, the max on the sidewall.
on performance tires with a much wider footprint, and more surface area to spread the weight out on, I air them down a little to prevent from ballooning out the tread and wearing them out in the middle.
so...not sure there IS a correct answer short of "it will vary with current use"
**Photobucket sucks**
#1229729
05/08/12 08:55 PM
05/08/12 08:55 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Most people run the max rated air pressure, but aren't at the maximum load capacity. They don't have enough weight to force the tire into the proper shape, so it wears in the middle of the tire.
They end up burning off the tread around the center of the tread pattern.
Assuming the proper size tire and rim, tire air pressure is all about adjusting the shape of the tire where it flexes against the ground given a certain load.
I use kid's chalk to rub a line across the tread. Then drive the car straight forward until it wears off enough to see how much of the tread is contacting the road. If the outside tread is lifted off the ground, I lower the air pressure until it scuffs off evenly and visa versa.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
#1229733
05/08/12 11:45 PM
05/08/12 11:45 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Within safe parameters, you'd be amazed at the profound affect some moderate F/R TP bias changes can make in a vehicle's handling characteristics. This can be a crutch to mask problems, of course (EG: look up TP specs for a Corvair), but it can also equal G-machine FUN!
Rick
[Re: ahy]
#1229736
05/09/12 12:11 AM
05/09/12 12:11 AM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
OK... I'll bite. How does it change?
Depends on whether you care to stare at the low tire message/warning or not
[Re: 70Cuda383]
#1229738
05/09/12 11:15 AM
05/09/12 11:15 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
depends.
Best post with honorable mention to jbc426.
I'm a bit of a stickler on the whole tire pressure issue because I have a fleet of trucks and trailers where tire pressure is even more important than it is on a car.
My dually has load range E tires with a max pressure of 80 psi; empty, I keep the fronts at 70 (that Cummins is HEAVY) and the rears at 55, loaded up to max GVW I put the fronts at 80 and the rears at 65 which is all they need to support the weight 'cause there is four of them.
Only thing I'd add is that I'd always error on the side of overinflation; far better to wear out the middle of the tire prematurely than to suffer a catastrophic failure due to excess heat caused by underinflation. Handling and mileage suffer with underinflation as well.
...the chalk test is a good one IMO.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
#1229739
05/10/12 10:54 PM
05/10/12 10:54 PM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
Always go off of the vehicles certification label in the door jam. The car goes through alot of vehicle dynamic testing to develop the appropriate characteristics that allow for the optimized condition. There are a few times when I would slightly adjust that thought process...in winter with ice, I drop a pound or two. For long highway trips I add a pound or two and for towing, I add about 5 extra PSI to the rears. As for TPMS...the system you describe sounds like an indirect which uses rolling radius and possible the tire harmonics to judge tire pressure. These systems are run through the ABS/Stability modulator, using the input from the wheels speed sensors and an algorithm to judge the pressure. Regulation has an allowance of 25% below the cert label pressure to set a light. When you push the button, it begins a calibration sequence that can take a long time to complete.Hence the inconsistancy of the light.
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
[Re: 4boxers4]
#1229741
05/14/12 12:33 PM
05/14/12 12:33 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the manufacturers recommendations are a compromise rather than an optimization--for example, the firestone rollover era explorers were found on their production validation testing to ride somewhat harshly, so instead of redesigning the suspension with changes to spring rates, shock damping rates, bushing durometer, etc, they lowered the tire pressure...IIRC it's somewhat ludicrously low, like 26PSI. that caused excessive heat, and in hot climates and high speed, enough to cause the tires to tear themselves apart.
I consider the door sticker the minimum for that specific tire/size. otherwise I prefer the chalk or drive through a puddle of water to check contact patch method....
my old 5th ave, which I put 255/50R17 BFG KDWS's (IIRC max pressure on the sidewall was 44-45PSI) it liked ~42 in the front and 40 in the rear.
my wife's grand caravan had P series bridgestones from the factory (36PSI max inflation. 35PSI on the sticker)), and I replaced them with Nokian WGR2 SUV tires (45 or 50 PSI max), and run those at about 43 PSI.
