Re: Fuel system with return line. [Re: Challenger 1] #1229575
05/11/12 10:40 AM
05/11/12 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
FWIW
I run a mechanical pump and factory style vapor separator with a return line. I have driven my cars all over the country in very extreme conditions and with all different kinds of gas. My car's fuel system is quiet, stock and dead reliable and would be easy to get parts for anywhere.
I don't need all that fancy racing stuff on my street car. How many of you can say you've driven your car at near wide open throttle for miles at a time, like over 5 miles at a time in 95 degree weather at 6000 feet alitutde? It never ran out of gas. I also drove it in 115 degree temps in Vegas last summer with the AC running the whole time.
I don't need no stinking vapor locking electric fuel pump on my street driven muscle car.
My carbs is bolted right to the intake manifold with no spacer/bandaid.
Its not the electric pump that is the problem...
pressure reduces vapor lock... its the carb.. I worked
on the 2.2 vapor lock problem and we ended up putting
a reservoir on the side of the carb with a return..
the carb was boiling all the fuel out of it and when
it fired and you took off hard it would fall on its
face till the pump could pump enough fuel in to cool
the carb and fill the bowl(till it cooled it was flashing
the fuel to a boil) keep the return line point as
close to the carb as possible... isolators do work
Re: Fuel system with return line. [Re: MR_P_BODY] #1229576
05/11/12 11:08 AM
05/11/12 11:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I understand that a electric pump can work fine on the street. The problem I see with performance pumps is that the suction line usually is not big enough expecially with a stock tank. Lot's of guys struggle with electric fuel pumps because of the suction side is not big enough for all conditions.imo
Yes the key is circulation to keep the fuel cooler.
Yup spacers can and do help alot, but my point is. Properly setup and tuned they are not needed, imo.
Re: Fuel system with return line. [Re: justinp61] #1229577
05/11/12 11:33 AM
05/11/12 11:33 AM
Az
Crizila Offline
Crizila  Offline
Az
I guess this thread isn't about a fuel delivery issue as much as it as about a fuel temp issue - although they can be some what related. Funny how this topic often pops up around this time of the year when stations are switching over from winter ( 14-16 RVP ) to sommer ( 8 - 10 RVP ) - expressed in PSI - blend. BTW, race gas is usually in the 5-7 RVP range, so not a problem. Cold climate areas also are the most effected as the change over has the biggest RVP swing. There aint no real good solutions for your high powered street machine, but here are some that may help. As said, a fuel return line system will help a little ( not for pre-soak issues though ). Dump your existing winter gas ( if your car has sat for a while ) and put it in the grocery getter ). Fill up from a station that is always busy - best chance to get summer fuel. Run a carb insulator type spacer. Lose those pretty stainless jacketed fuel lines and replace them with ANYTHING not covered with a steel braided jacket. Run the lines / regulator as far away from the engine as possible. Get the heat out of the engine bay. Run electric fans for a few minutes after shutdown - like at the gas pump while you are filling up or - raise the hood. Remove the inner fenderwell splash guards. Raise up the back of the hood an inch or two ( ala old school ). Run a 160 stat - if your system can stay on it - or no stat. Insulate your headers - and fuel lines. BTW, the fuel in the old Thermoquad ran about 10-15 degrees cooler with their plastic fuel bowls ( guess this problem has been around for a while ). Looks like the new Demon street carbs are trying to address it also. IMO, the biggest problem is heat trapped in the engine bay. What ever you can do to reduce it will be the biggest help in solving this problem.
Fastest 300
Re: Fuel system with return line. [Re: Crizila] #1229578
05/12/12 12:12 AM
05/12/12 12:12 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I run a 1" plastic spacer and even put a heat shield under the carb to see if it helps. It only seems to do it after its hot and shut down for a few minutes you know a hot soak. Thats when it seems to happen. Never had any problems last year or ever before. Ron
Re: Fuel system with return line. [Re: Challenger 1] #1229579
05/12/12 12:19 AM
05/12/12 12:19 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
FWIW
It has nothing to do with the fact I use an electric pump. The electric pump is better for fighting vapor lock since fuel is coming up under pressure. There is no way a mech pump would be better and I would not waste my time using one. There is no way you could drive your car here in Md using this pump gas with no heat spacer under the carb at 115 degrees. Either your car only runs 140 degrees or you have some mighty fine gas out there. Ron
Re: Fuel system with return line. [Re: 383man] #1229580
05/15/12 10:54 AM
05/15/12 10:54 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Under extended WOT high speed conditions there is usually plenty of airflow in the engine bay and lots of fuel consumption keeping everything reasonably cool.
In other words, the exact opposite of what causes the issue
Rich H.
Esse Quam Videri
