XE274 cam #1229289
05/08/12 03:49 AM
05/08/12 03:49 AM
LaFollette TN 37766
3
383ramd150 Offline OP
LaFollette TN 37766
Hello,I am new to the webite and was just wanting here about some of your guys sb 318 builds using Comp XE274 cam!I am building a 318 bored .040 over with kb167 pistons zero decked with edelbrock performer rpm heads and airgap intake with 650 holley dp!Comp is gonna be 10.1 with heads milled!Short block is being built by Hensley performance and I was trying to decide on xe268 or xe274 cam.This is going in 83 d150 2wd with built 727 and 8.75 with 4.56 gears!Just wanted to here some of your thoughts?Help is really appreciated and thanks!
Re: XE274 cam [Re: 383ramd150] #1229290
05/08/12 09:21 AM
05/08/12 09:21 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I would of built a 360. More bang for the same buck.
I am truckless..
Re: XE274 cam [Re: 383ramd150] #1229291
05/08/12 09:36 AM
05/08/12 09:36 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The guy has a 318, so that's what he wants to build.
I would not be afraid of that 274 cam with your 4:56 gears.
I run the MP 474(which I think is close to the X274) cam in my 340 and like it with 3:55 gears.
Good luck with your build.
Re: XE274 cam [Re: 383ramd150] #1229292
05/08/12 09:50 AM
05/08/12 09:50 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
If you're running 4.56's, then don't hesitate to run the xe 274....but anything less and a 318, you'd be fine to stick with the 268, especially if you're running eddy heads.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: XE274 cam [Re: 383ramd150] #1229293
05/08/12 10:43 AM
05/08/12 10:43 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
What stall? If it flashes high enough I'd go a step higher cam with a engine like yours, perhaps a XE284H.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: XE274 cam [Re: DARTH V8Я] #1229294
05/08/12 01:25 PM
05/08/12 01:25 PM
dogdays Offline
dogdays  Offline
Small motor in a pickup which by nature is heavy?
Go for the smaller cam.
Your heads will take care of any breathing issues there are and don't need to be crutched by a big cam.
R.
Re: XE274 cam [Re: dogdays] #1229295
05/08/12 01:37 PM
05/08/12 01:37 PM
LaFollette TN 37766
3
LaFollette TN 37766
I have a 727 with 2800 stall!Also using mp heavy duty rockers!318 was all i have but it is eventually gonna get a bigblock!
Re: XE274 cam [Re: 383ramd150] #1229296
05/08/12 03:16 PM
05/08/12 03:16 PM
LaFollette TN 37766
3
LaFollette TN 37766
Also there aint many built 318s around here but alot of 340 and 360's!Just want to see what the 318 is packing!
Re: XE274 cam [Re: 383ramd150] #1229297
05/08/12 03:21 PM
05/08/12 03:21 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
Just depends on how much money you want to put into it
Re: XE274 cam [Re: dogdays] #1229298
05/08/12 08:59 PM
05/08/12 08:59 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
R.
Normally I agree with you, but if hes making 300hp @ 5250 he's also making 300lbs-ft @ 5250. Remember that \6's ran these things too with realitive ease..
Re: XE274 cam [Re: DARTH V8Я] #1229299
05/10/12 01:03 PM
05/10/12 01:03 PM
LaFollette TN 37766
3
LaFollette TN 37766
Well looks like the xe274 gets the votes!Thanks guys!
Re: XE274 cam [Re: 383ramd150] #1229300
05/10/12 01:06 PM
05/10/12 01:06 PM
dogdays Offline
dogdays  Offline
It's a mistake. It is possible to overcam an engine. What size tires are you going to run in back?
R.
Re: XE274 cam [Re: dogdays] #1229301
05/10/12 01:36 PM
05/10/12 01:36 PM
LaFollette TN 37766
3
LaFollette TN 37766
28in 295/55/15 MT ET streets!I talked to Ken Hensley,He said i would be happier with XE268 cam and going with 4.10 gear and be much better cruise!So I gonna use the xe268!Now my issue is they asked me about milling my heads,with kb167 pistons and these heads out of box would give 9.7to1 comp but milling them could get 10.1 or could go to 10.5 comp and still run pump.What would you guys do?
Re: XE274 cam [Re: 383ramd150] #1229302
05/10/12 01:41 PM
05/10/12 01:41 PM
LaFollette TN 37766
3
LaFollette TN 37766
The only problem i have is that eventually i gonna take it to track for some test and tune nights at and all we have close is 1/8th mile!Will 4.10 gear be enough!The stall i do have is boss hogg 2200-2800 stall
Re: XE274 cam [Re: 383ramd150] #1229303
05/17/12 03:40 AM
05/17/12 03:40 AM
LaFollette TN 37766
3
LaFollette TN 37766
Found out that i can mp 284/528 cam cheap new in box.How good would this cam be in 318?
Re: XE274 cam [Re: 383ramd150] #1229304
05/17/12 03:45 AM
05/17/12 03:45 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I haven't read this post,but without good compression,converter,gear it will be a turd.
Re: XE274 cam [Re: goldmember] #1229305
05/22/12 10:37 PM
05/22/12 10:37 PM
LaFollette TN 37766
3
LaFollette TN 37766
Well,I am thinking of going solid.Has anybody used comp xs268s cam with 230/236 duration @50 and 488/501 lift?Or should i go step bigger?
Re: XE274 cam [Re: 383ramd150] #1229306
05/22/12 11:15 PM
05/22/12 11:15 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
If you're unsure of which cam to use, always go with the smaller of the two.
Re: XE274 cam [Re: JoesMopar] #1229307
05/23/12 10:56 AM
05/23/12 10:56 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Look at whatever cam catalog you have decided to use. Go clear to the bottom of the list where the biggest and baddest cams live. Look at them, don't buy them. work your way up the list. Its OK to close your eyes and imagine what they would sound like but don't buy them. When you get to the one that looks too small but says it will work in a 318 truck, BUY IT.
Re: XE274 cam [Re: DARTH V8Я] #1229308
05/23/12 05:38 PM
05/23/12 05:38 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
R.
/6 engines made these trucks move, sure, but a ten speed bicycle is faster off of the line. With the gears, stall, and tires this guy is running my guess is he wants to go fast.
Eddie heads, big valves, small bores, an XE-274, and valve shrouding are, at least to me, a recipe for a really lazy motor. Even if it produces decent numbers up top the usable power curve down low is going to be flat.
All of this aside, you if plan on going big block later on in the life of this project, why blow $1400 on a set of heads you can't reuse on the new motor?
