How hard is it to find choke well gaskets?
#1228383
05/07/12 12:21 AM
05/07/12 12:21 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I looked through the gaskets sets that I have sitting around (always keep stray gaskets) and I don't have a choke well gasket for the 440. The gasket on the Imp is leaking. I have some gasket material and made one of my own. It ended up leaking and blowing out pieces. I'd really like to get the exhaust gasses out of the engine compartment.
Re: How hard is it to find choke well gaskets?
[Re: JohnRR]
#1228387
05/07/12 12:40 AM
05/07/12 12:40 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I might have one around in my box 'o gaskets.
I might also .
So which one of us feels like walking out to the garage to check first ?
[Re: OzHemi]
#1228392
05/07/12 01:14 AM
05/07/12 01:14 AM
feets
Senior Management
Senior Management
Irving, TX
Oz, where did you find those things? I don't have any from the gasket sets I've used in more than 15 years. I never throw away gaskets and I don't mess with stock intakes (until now). I have several motorhome/industrial RB water pump gaskets, lot of valve seals, and oodles of manifold head pipe gaskets but not a single choke well gasket.
[Re: feets]
#1228393
05/07/12 01:18 AM
05/07/12 01:18 AM
OzHemi
Garden Grove, CA
Who knows..
I did end up with a few odd ball gaskets back when I worked at the dealership though.
One of them is just a fiber gasket and the other has the perferated metal like an exhaust manifold gasket on it.
[Re: 68HemiB]
#1228397
05/07/12 01:19 PM
05/07/12 01:19 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
P5249639 for both the gasket and the cup, priced lower than just the cup by itself
Don't you just love that sort of thing?
It's usually the other way around , priced higher than the 2 parts separate .
[Re: DusterJeff]
#1228399
05/08/12 01:44 AM
05/08/12 01:44 AM
feets
Senior Management
Senior Management
Irving, TX
The exhaust would cook the Permatex. That stuff isn't designed for the super high heat of exhaust gasses.
I know some people put it on exhaust manifold gaskets but I'd bet they're wasting their time. Ultra Copper is advertised for 700 degrees for intermittent use. I don't know that it would survive higher exhaust temps under WOT. You're looking at 1200 degrees and higher.
