How to test for a bad coil
#1228125
05/06/12 08:52 PM
05/06/12 08:52 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
It seems as if my car has lost spark. Cranks fine, fuel seems fine. Will not start. Ballast resistor checks out OK. Is there a good way to test to see if the coil is bad? We seem to have connectivity/juice on both sides of the coil but don't seem to have any output from the coil. What is the best 'next step' if the coil tests all right? Any suggestions apprieciated. thanks! ![](/ubbthreads/images/graemlins/beer.gif)
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
Re: How to test for a bad coil
[Re: 69CoronetRT]
#1228129
05/07/12 10:05 AM
05/07/12 10:05 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Did you pop the coil wire out of the cap, crank it and see if you have sprak?
Yes and we do not have any sparking. I just want to see if there are other ways to confirm if the coil is bad before we start replacing things that don't need replacing.
right on, Do you have a spare coil? easy enough to swap. Get the gauge out and start checking.
[Re: Mr.Yuck]
#1228130
05/07/12 10:53 AM
05/07/12 10:53 AM
RapidRobert
Use a jumper wire with alligator clips on each end to ground the coil negative primary terminal repeatedly like Morse Code & see if that makes the coil secondary wire (dist end) held 1/4" from ground produce sparks while a helper holds the key to start. Can unplug the yellow "sol" wire at the starter relay to disable the starter for this test. Best is to 1st take off all wires from the coil neg primary terminal. If it sparks it's good but a coil can test good cold then act up when at operating temp but this'll get you started
[Re: RobX4406]
#1228133
05/07/12 02:09 PM
05/07/12 02:09 PM
69CoronetRT
Harlan, Iowa
Thanks everyone. Very helpful! ![](/ubbthreads/images/graemlins/beer.gif)
Seeking:
