Re: How do I tell if I found a "REAL" 440 Six Pack Engine??
[Re: 70440+6bbl]
#122807
09/18/08 09:36 PM
09/18/08 09:36 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Only real way to tell is if it has the cast pistons with 4 valve reliefs and 3 bolt timing chain. If out of a '70, it will have F440Hp or HP2 stamped on the id pad up top. The VIN stamping on the passenger side oil pan rail will be stamped 0B***** if it was in fact out of a '70 'Cuda or Challenger. The "big" balancer was used on all 440 4bbl Hi-Po and 6bbl engine starting in 1970-1972. The end carbs should be 4382 and 4383 (center #'s were different depending on tranny). The block part # is the same for all '70 440's. The 440-dash # is the core shift IIRC.
So after all that please tell me how a person would know its a "real 440-6" vs one that was just put together with the above parts?????
[Re: Pacnorthcuda]
#122808
09/18/08 09:47 PM
09/18/08 09:47 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
Ha! Thats what thought? Its suppose to have a 4speed trans to go with it. Also (you guys are going to flip) There;s suppose to be a 72 Road Runner sitting there also with a 440 with the Edelbrock 6pak intake thats also 100% complete, AND its suppose to have 4speed too, BUT its rusted real bad.
I will take pics IF this turns out to be a real find and not someones pipe dream.
[Re: High Impact]
#122809
09/18/08 09:50 PM
09/18/08 09:50 PM
Pacnorthcuda
Tranny will prove nothing, only that it DID or DID NOT come with the engine block. and they DID make 440-6 Automatic cars too!!!
[Re: Alaskan_TA]
#122812
09/18/08 10:22 PM
09/18/08 10:22 PM
High Impact
Manistee, Michigan.
If this turns out to be anything.................which Im not holding my breath....................... I will post what I find here. Its not a REAL 72 Road Runner with the 6pack just a car that is suppose to have a 6pack on it and be a real P.O.S. too! Who knows what Im going to find but hey, when someone tells you of somthing you gotta check it out!
[Re: Pacnorthcuda]
#122813
09/18/08 10:24 PM
09/18/08 10:24 PM
High Impact
Manistee, Michigan.
and a 440-6 72 runner?????? lol.
Their's always one guy...............................................
[Re: 1972Rallye]
#122816
09/19/08 08:04 AM
09/19/08 08:04 AM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
The only way to know if the engine is a REAL Six Pack engine is to verify the VIN matches a REAL Six Pack car. There are no markings/casting #'s/stampings that are exclusive to Six Pack engines. Parts... yes.
becareful , those hawking HP2 blocks as 6pk blocks for big money aren't going to like that.
to the OP if the engine is UNMOLESTED there is a way to determine that is COULD be an original 6pk engine , but you would have to partially disassemble it to find out , if it's already apart and the guy doesn't have a valid REAL title to the original car all bets are off .
[Re: 1972Rallye]
#122820
09/19/08 09:17 AM
09/19/08 09:17 AM
High Impact
Manistee, Michigan.
I think it's time for this one.
Outstanding!
Well, Im off to go see what this guy has..................watch it be a pontiac motor or something! Im taking the camara just in case it turns out to be something coooooool
