Cuda Wont Start #1228048
05/06/12 04:46 PM
05/06/12 04:46 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
This morning I went out and tried to start the Cuda. Got it running finally but i have to hold the Ignition switch in between the start and relaxed position to keep it running. Sounds like a ign switch problem? Any other ideas?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cuda Wont Start [Re: 19cuda73] #1228049
05/06/12 05:29 PM
05/06/12 05:29 PM
louisville ky
67gtxclone Offline
67gtxclone  Offline
louisville ky
i had a similar problem and it was the ignition switch i replaced it and all was good
Re: Cuda Wont Start [Re: 19cuda73] #1228050
05/06/12 08:19 PM
05/06/12 08:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What year? Check the ballast resistor. Try bypassing/jumper the ballast resistor for a few seconds and see if it will run with the key in the "relaxed" position.
If so, replace it. If not, it's likely the key switch.
Re: Cuda Wont Start [Re: jbc426] #1228051
05/08/12 04:46 AM
05/08/12 04:46 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
73 Thanks for the tips I did check the ballast resistor first, no change then put the new switch in. When I rebuilt the column I should have just changed it out then but live and learn. Were back on the road.
1972 Corvette
