trans leak 67 belvedere #1228043
05/06/12 04:39 PM
05/06/12 04:39 PM
louisville ky
67gtxclone Offline OP
louisville ky
hey folks i have a 1967 belvedere i recently had the trans rebuilt but i have a very small leak somwhere in the unit. after sitting overnight there is a small puddle on the garage floor it appears that the leak is coming from around the speedometer cable is there supposed to be some sort of seal on this cable i dont remember one when i disassembled the car thanks for any info
Re: trans leak 67 belvedere [Re: 67gtxclone] #1228044
05/06/12 05:13 PM
05/06/12 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is a small lip seal inside the adapter that the cable threads onto, it's possible that your rebuilder didn't replaced it and fluid is leaking into the cable housing.
You can see the seal in the pic below held in place by a wire ring.
Re: trans leak 67 belvedere [Re: John_Kunkel] #1228045
05/06/12 05:31 PM
05/06/12 05:31 PM
louisville ky
louisville ky
Ahh Haa i appreciate the pic i'll run it by the trans shop and have him check it thanks for the help
