Leaf spring load numbers #1227759
05/05/12 07:19 PM
05/05/12 07:19 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Something I found that I would be helpful. Tim
7193764-Springrates.pdf (1707 downloads)
Re: Leaf spring rates [Re: astjp2] #1227760
05/05/12 08:01 PM
05/05/12 08:01 PM
IN
ahy Offline
ahy  Offline
IN
Re: Leaf spring rates [Re: ahy] #1227761
05/05/12 10:53 PM
05/05/12 10:53 PM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Wow, your timing couldn't be more perfect!
I have a set ov leafs from a 69 B-wagon, and they match that description perfectly... 5 leafs (plus one half actually), pretty good arch, width, etc.
So "960" is the spring rate then? Sounds more like a load, and if so, where are the rates? I'd really like to know... i have to order matching T-bars for them this week.
More load (again, if i'm correct) than a hemi spring too, which is good for my uses. But with a thinner pack (wagon 1 5/16" vs hemi 1 5/8" & 2") they might be a lesser rate than the hemi?
Re: Leaf spring rates [Re: Pale_Roader] #1227762
05/06/12 12:00 AM
05/06/12 12:00 AM
IN
ahy Offline
ahy  Offline
IN
I believe the XHD springs sold today are re-pops of the Hemi spring.
I got my XHD's where I wanted them in an E by adding one full length leaf. They seem to match well with 1" T bars.
Re: Leaf spring rates [Re: Pale_Roader] #1227763
05/06/12 12:00 AM
05/06/12 12:00 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I know in the offroad world, thinner leaves and more of them will flex more. Tim
Re: Leaf spring rates [Re: astjp2] #1227764
05/06/12 12:46 AM
05/06/12 12:46 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't understand what is the "load capacity" rating represents.
That is NOT the spring rate in LBS/IN. Factory rear springs are 100-140 lbs/in range.
Sometimes in the facotry sales books they list rear leaf spring ratings. There are some leaf spring rates in the old edition Direct Connection books. I know the A-body rates are in there.
Re: Leaf spring rates [Re: autoxcuda] #1227765
05/06/12 01:17 AM
05/06/12 01:17 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Re: Leaf spring rates [Re: astjp2] #1227766
05/06/12 09:01 AM
05/06/12 09:01 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It looks like part numbers for Triangle Spring, a manufacturer. However other manufactuers may use a similar p/n system. Triangle sells through retail spring shops, eg. Jenson & Mitchell in North Jersey. As of a few years ago, Springs & Things was mail order retailer for Triangle.
edit: question answered! Thanks!
Stengel's list for a-bodies doesn't turn up the Triangle p/n for the springs I used (78-709 or the less arched version 78-609). Either its a different mfc or partial listing. It is certainly a helpful listing!
For the springs that are available on-line, they also include the OEM p/n that it replaces. So with a bit of research you can cross reference to a Chrysler-Plymouth or Dodge parts book.
For example (a-body sorry I didn't copy all the other ones down when I was at the dealer).
Stengel Bros p/n 78-581 replaces OEM 2808677 and 2835056.
2808-677 was for 383 equiped Darts and Barracudas 1967 - 1969. HD 383s only at least in '68-9
It used main leaf p/n 2808 688 unique to the 2808 677 spring packs. Thicker? Different Arch? I don't know but would like to find out.
Further, the DC Chassis Rally Prep chapter notes 2808-677 has a wheel rate of 130 #/inch and no increase in lift.
Finally, the shop manuals indicate these cars should have 6 leaf rear springs, left and right same.
I don't have any notes on the 2835056. However by 1969, new leaf spring p/n were coming on line starting with 3004. It might be a '68 only part number.
Re: Leaf spring rates [Re: autoxcuda] #1227767
05/06/12 02:28 PM
05/06/12 02:28 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Abridged summation from the chassis manual;
Spring rate is the amount of force it takes to compress the leaf pack one inch.
Load rate is the amount of weight it takes to hold the leaf pack in a flat position.
Control rate is the ratio of stiffness in the front segement compared to the rear segment. 1 means the front is as stiff as the rear. Production rates range from 1 to 1.4. SS rates range 1.4 to 1.8.
Re: Leaf spring rates [Re: TC@HP2] #1227768
05/06/12 03:36 PM
05/06/12 03:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So you take the Spring Capacity (Load Rating) divided by the Arch (Free Arch)???....
Ok I tried that for what I think is thier 70-72 340 heavy duty leaf spring p/n 78-611 and I get 112.78 lbs/in. That sounds about right. 340 springs were listed as 110 lbs/in in factory literature.
I think the Stengal 78-581 is the 68-69 340 leaf spring. That calcs to 106.67 lbs/in. Factory list that as a 110 lbs/in spring... Close.
Re: Leaf spring rates [Re: autoxcuda] #1227769
05/07/12 12:51 AM
05/07/12 12:51 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Click on that p/n and the link shows the Chrysler p/n.
Now you made me look at my '68 Book CD
It still looks like that Chrysler number is only for some 383 equiped L, & B models 1967, 1968, 1969
1968 Standard
Valiant, Dart 225cid 3004 581
Barr H T 225 3004 582
Barr Cnv, Ht Spcl 225 3004 585
Barr 318, 383 3004 588
Dart 318, 340 3004 583
Heavy Duty from the '68 Parts Book:
V,L /6,273,318 3004 584
L2-S 340 3004 584
B exp 383, 3004 588
B 383,L2-S383 2808 677
My notes are that the '69 Parts Book give the following spring numbers for both the 318 & 340 cars.
V,L,B 3004 584
Presumbly this is the spring used in '68 340 equiped Barracudas. I don't have supplementals for books.
To confuse things a bit, from the Chassis Manual, Ralley Prep, page 58:
340 H.P. 3549 059 110 lb/in 0" increase
Looking at the part parts books on Cd helps correct my notes, correction made in previous post regarding applications.
Re: Leaf spring rates [Re: ahy] #1227770
12/18/12 04:14 PM
12/18/12 04:14 PM
Round Rock, Tx
PlumCrazyChris Offline
Round Rock, Tx
I got a little more info about spring rates.
I was trying to compare the rate of the Hotchkiss rear springs, at 160 lb/in, they sounded pretty stiff, but I had no comparison. This is what I came up with.
FYI Hotchkis T-bars say they are 200 lb/in. @ 1.03" diameter.
VP of Mopar Muscle Cars of Austin
70 Challenger
www.mopar.org
Re: Leaf spring rates [Re: PlumCrazyChris] #1227771
12/18/12 04:17 PM
12/18/12 04:17 PM
Round Rock, Tx
Round Rock, Tx
Here are the Torsion bar spring rates
70 Challenger
www.mopar.org
Re: Leaf spring rates [Re: PlumCrazyChris] #1227772
12/18/12 04:47 PM
12/18/12 04:47 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
And... to the list for 41" B and E-bodies, the 1.24" dia TB can be added at 425 lbs/in (I run these in my autocross T/A)... along with 225 lbs/in fiberglass mono-leafs having an uncompressd 5" arch (leaving about 1.5" uncompressed arch in race-trim).
Re: Leaf spring rates [Re: Mopar Mitch] #1227773
07/09/13 07:21 PM
07/09/13 07:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Digging up an old thread. I found that the numbers on my 68 Dart GSS 440 car are 2835056 and I found a set of springs in my stash that have the number 2835064 that look identical, does anyone know what these springs fit?
JB Rhinehart, Realist
A-Body's RULE!
Re: Leaf spring rates [Re: Rhinodart] #1227774
07/25/13 11:34 PM
07/25/13 11:34 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Re: Leaf spring rates [Re: 1969ronnie] #1227775
07/25/13 11:44 PM
07/25/13 11:44 PM
1969ronnie Offline
1969ronnie  Offline
hi,the 6 leaf 2835064 fits 68-69 a body 340 cars. the main leaf on your 2835056 is different than the 2835064 main leaf. look at the front spring eye for different bushing dia. ,ronnie
Re: Leaf spring rates [Re: Rhinodart] #1227776
07/25/13 11:58 PM
07/25/13 11:58 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
2835056
2835064
Neither of those numbers show in the numerical index of the '68 parts book.
Maybe someone more knowledgable about original parts and assemblies can can explain.
The closest items in the same to a 68 Dart GSS 440 is the
L2-S, 383 eng .....2808 677
Re: Leaf spring rates [Re: TC@HP2] #1227777
07/26/13 01:20 PM
07/26/13 01:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have not heard that ratio discussed in detail before, what downside would there be of say a 100:1 control rate? Is it a related roll rate problem?
Re: Leaf spring rates [Re: jcc] #1227778
07/29/13 02:25 PM
07/29/13 02:25 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Hmm. I don't know at what ratio does it becomes a practical solid link and the direct relationship of a control rate to roll rate issue. I'd certainly think that at higher control ratios you are altering which section(s) of the spring yields first to various loading conditions.
