Page 1 of 4 1 2 3 4
Troubles getting timing set on 360 #1227175
05/04/12 04:04 PM
05/04/12 04:04 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
So, many of you recommended that I set the initial (idle) timing on my 360 in order to better diagnose the rough idle problems I'm having... I tried doing that today, and seem to be either completely stupid, or having some other problems. I have a timing light that has a dial on it...
I hooked up the timing light to the #1 plug wire, as close to the boot as possible, and then get the car to idle (around 1000 rpm). disconnected and plugged the vacuum line that goes to the vac advance on the distributor. When I set the dial on the timing light to 16 (what I've been told to set my idle timing to), and rotate the distributor until the timing mark on the balancer line up at 0 on the water pump, the timing mark doesn't seem to be there on "every" flash of the timing gun... is there something else going on? Also, is this the proper way to set the initial timing where it needs to be?
Also, just to set my baseline, I make sure all my spark plugs (autolite AL65) were set to .034, and set each idle mixture screw on the carb (Edelbrock 1405) to 1.5 turns out.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227176
05/04/12 04:14 PM
05/04/12 04:14 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Sounds like you may be cross-firing in the cap or between wires. OR, your light has issues...
16 initial sounds like too much, but all I've ever had were very stock motors.
Re: Troubles getting timing set on 360 [Re: Jim_Lusk] #1227177
05/04/12 05:55 PM
05/04/12 05:55 PM
Sacramento, CA
Sacramento, CA
can't get it to idle low enough to set idle timing properly... my neighbor (mechanic) came over and said he thought I had a vacuum leak.. he showed me that by putting his hand over the front openings of the carb, that it increased the idle and ran better.. he said that's an indicator of a vac leak.. sound right?
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227178
05/04/12 06:34 PM
05/04/12 06:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He is correct.
Re: Troubles getting timing set on 360 [Re: stumpy] #1227179
05/04/12 06:45 PM
05/04/12 06:45 PM
Sacramento, CA
Sacramento, CA
carb is off.. I'm taking it to a carburetor rebuild shop to have them go through it for me. I've done it once before, and obviously didn't know what I was doing.. otherwise I wouldn't be having these problems.. so... off to go spend $189 on a rebuild
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227180
05/04/12 07:01 PM
05/04/12 07:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you changed intake manifolds recently. That could cause a vacuum leak. When you disconnected the vacuum line to set the timing did you plug the carb vacuum port? Just checking the obvious.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227181
05/04/12 07:04 PM
05/04/12 07:04 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
A vacuum leak on an ede carb is usually not an internal issue. It's a sealing issue between the baseplate and intake. IMO, taking it to a shop is just burning money at this point. You really need to do the simple stuff first, like locating the actual source of the leak, before throwing cash around.
If the intake has an hourglass shape opening like a performer, it's going to need a 2732 (???) plate to seal it up. Carb linkage also hangs up on the intake sometimes causing leaks. Power brakes? Disconnect EVERYTHING vacuum related from the carb and plug it, see if that helps. If it does, then hook each item back up until you find the offender.
No timing tape or marks on the balancer for 15 and 30 degrees BTDC and you'll never know where the mark is unless you have a dialback light. Put the inductive pickup where ONLY the #1 wire is located, up front near the plug. Just don't burn it on exhaust manifold/headers. No need to place it near the cap if that's what you did.
Re: Troubles getting timing set on 360 [Re: RobX4406] #1227182
05/04/12 10:50 PM
05/04/12 10:50 PM
Sacramento, CA
Sacramento, CA
So, I realized that the vacuum port on the back of the carb that was going to the power brake booster was not a 'solid' fitting, it was a brass fitting that was meant to be pressure fit on the inside.. it was 2 pieces.. the nipple part and the nut part that had the threads on it to screw into the carb body... and it was wobbly.. so it was clearly a source of vacuum leak. I went out and got a solid 1 piece brass fitting and took your advice, and plugged it off for the sake of the tuning process. I blocked off the vacuum port going to the distributor too. I am wondering if something else is going on ...because even when I move the timing to 18 degrees at idle, it barely wanted to idle at 900 rpm. Then, when I revved it up, it would go up to about 38 degrees advance.
when I hooked up the vacuum advance back to the distributor, the idle timing jumped up to about 38 at idle, and when revving, it went all the way up to about 55 degrees. How is that possible?
I freaking hate this crap. I'll take body and paint work over this any day. I shoulda just dropped a Mustang 5.0 in the Miata and been done!
Think I may put a posting up on Craigslist looking for someone who knows how to tune Mopar engines in the Sacramento area, and see if I can get someone local to do it for me.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227183
05/04/12 10:59 PM
05/04/12 10:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is the vacuum port you are using for the advance ported or full? Pvacuum is above the butterflys and full vacuum is below. You want ported for advance.
Re: Troubles getting timing set on 360 [Re: stumpy] #1227184
05/04/12 11:22 PM
05/04/12 11:22 PM
Sacramento, CA
Sacramento, CA
Yeah, it's ported vacuum.
Re: Troubles getting timing set on 360 [Re: stumpy] #1227185
05/04/12 11:24 PM
05/04/12 11:24 PM
RobX4406 Offline
RobX4406  Offline
You need to do ONE STEP at a time. Don't fricken worry about where your total falls right now, I DOESN'T MATTER. Get the idle sorted out first.
The more you dick around with other areas, the more it will be confusing.
If the idle advance jumps a bunch when you hook up the vacuum advance line, it's not right. There should be ZERO advance from the vacuum can at idle on a ported line.
Just because you blocked off that one point DOES NOT mean you don't have a leak elsewhere. What intake is on the car?
Maybe you really should find someone local that can help you out and walk step by step through the process.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227186
05/04/12 11:27 PM
05/04/12 11:27 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
a ford? whats up with that.this is a mopar site,sounds like basic troubleshooting to me,reguardless of brand. so you think just drop in a 5.0 and all your mech. issues are over.wow
Re: Troubles getting timing set on 360 [Re: mcmopars] #1227187
05/05/12 12:01 AM
05/05/12 12:01 AM
Sacramento, CA
Sacramento, CA
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227188
05/05/12 12:13 AM
05/05/12 12:13 AM
RobX4406 Offline
RobX4406  Offline
Do you have this plate under the carb?
It sounds better. You're getting closer. If you turn the idle screws in does the idle quality change?
It sounds like it's got a miss in it, might be the video itself.
What's the line all the way across on the timing tape in your video?
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227189
05/05/12 12:22 AM
05/05/12 12:22 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Most likely becouse your vac.can on the dizzy has 8.5 degrees of advance (17 @ the crank), & you have it hooked to full vac. port.
Have paitience, ask all the questions you need to and your problem will be solved
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Troubles getting timing set on 360 [Re: RobX4406] #1227190
05/05/12 12:23 AM
05/05/12 12:23 AM
Sacramento, CA
Sacramento, CA
No, I've got the carb bolted directly to the intake (with a gasket in between).. It's a Performer intake and a Performer carb, I was under the impression that I wouldn't need anything other than the gasket between them. It is getting better.. but it's still not right. This is exceptionally frustrating. I'm having a cocktail now.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227191
05/05/12 12:25 AM
05/05/12 12:25 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you need the piece that is shown above to seal the deal...
that part comes with the performer intake from edelbrock for a reason..
Tony
70 AARCuda Vitamin C
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227192
05/05/12 12:29 AM
05/05/12 12:29 AM
RobX4406 Offline
RobX4406  Offline
That intake carb combo needs that plate. It's the hourglass shape question I asked earlier.
See instructions, bottom of page 3.
http://static.summitracing.com/global/images/instructions/edl-2176.pdf
Re: Troubles getting timing set on 360 [Re: 70AARcuda] #1227193
05/05/12 12:31 AM
05/05/12 12:31 AM
Sacramento, CA
Sacramento, CA
That's what I get for buying the intake and carb "used" ... I'll see if I can get that part. I was using a 1" spacer to help reduce heat soak to the carb, but I got rid of it in an effort to reduce vacuum leaks.
Also, to the question about the line across the timing tape on the video.. i think that's just an anomaly with the frame rate of the video and frequency of the flash from the timing light.
Re: Troubles getting timing set on 360 [Re: cal_gecko] #1227194
05/05/12 12:36 AM
05/05/12 12:36 AM
RobX4406 Offline
RobX4406  Offline
Those plates are about $7 at O'rielly's or autozone IIRC.
They tend to get "lost"...
That 1" spacer may do the same, however, it introduces other potential issues. Get that plate #2732 and try again.
Reset the carb idle mix screws to 1.5 turns out. If you get the plate on, the idle should increase a bunch because your leak should be gone.
Page 1 of 4 1 2 3 4
