magnum wont start randomly.... #1227025
05/03/12 11:47 PM
05/03/12 11:47 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I have a 2005 dodge mangnum RT, its got about 130,000 on it. I had a no start condition about 6 months ago, it was just dead. flat dead. Pulled the battery (orig mopar batt.) had it tested was told it was bad. Replaced it with a new one, had the same issue creep up.
if the car sits more than 3 days its almost a guarantee it wont start.
Sometimes it wont start from sitting overnight, like 8 hours.
The battery will be dead to the point no interior lights come on, the keyless entry is gone etc... just flat out dead.
Has anyone heard of this?
know of sure fire way to detect ABNORMAL drains?
Re: magnum wont start randomly.... [Re: 8urvette] #1227026
05/03/12 11:49 PM
05/03/12 11:49 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Just to rule it out, I'd have the new battery tested.
It's Swifty! Swifty, you toad sucker!
Re: magnum wont start randomly.... [Re: zrxkawboy] #1227027
05/04/12 01:40 AM
05/04/12 01:40 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i will do that, but for it to RANDOMLY not start with a dead battery... i just don't get it, no rhyme or reason.
this gets to be very frustrating
Re: magnum wont start randomly.... [Re: 8urvette] #1227028
05/04/12 08:29 AM
05/04/12 08:29 AM
NEW JERSEY
TLEARN 23 Offline
TLEARN 23  Offline
NEW JERSEY
IF THE DRAW IS HEAVY ENOUGH IT SHOULD LIGHT A TEST LIGHT BETWEEN THE NEGATIVE BATTERY TERMINAL AND THE NEGATIVE BATTERY POST. YOU MUST REMOVE THE CABLE FROM THE BATTERY AND PUT THE TEST LIGHT BETWEEN THEM. iF THE BULB LIGHTS THEN START UNPLUGGING THINGS STARTING WITH THE ALTERNATOR FOLLOWED BY FUSES. LEAVE THE FUSES OUT UNTIL THE CIRCUIT WITH THE DRAW IS FOUND. iF YOU DO THIS AND THE TEST LIGHT NEVER DOES LIGHT THE BULB YOU MUST USE ANOTHER MEANS FOR CHECKING A SMALLER DRAW WHICH CAN BE DONE WITH AN OHMMETER.
Re: magnum wont start randomly.... [Re: TLEARN 23] #1227029
05/04/12 02:02 PM
05/04/12 02:02 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
thanks, i will be trying this tonight. I was hoping that others had had this issue and knew exactly what it was.
Re: magnum wont start randomly.... [Re: 8urvette] #1227030
05/04/12 05:42 PM
05/04/12 05:42 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I had a 94 LeBaron conv, that started doing this battery drain, found out it was a short in the inst. cluster.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: magnum wont start randomly.... [Re: Magnumguy] #1227031
05/04/12 08:47 PM
05/04/12 08:47 PM
IN
ahy Offline
ahy  Offline
IN
I had a PU of that era that would drain the battery if the key was left in the ignition.
As posted, pull the battery cable and use a test light first to check for current drain between the batt cable and battery post. If it lights up, start pulling fuses one at a time until you find the problem circuit. If the test light is faint, you can use a multi meter ammeter to test for drain. On a modern car, 20 mA drain is normal (good) up to 40 or so MA is OK.
Draining a battery in a day or two would take a lot more than 40 mA.
Re: magnum wont start randomly.... [Re: ahy] #1227032
05/05/12 01:48 AM
05/05/12 01:48 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
thanks, good info. does not look like ill be getting to it tonight.... hopefully tomorrow!
