vacuum advance #1226848
05/03/12 07:15 PM
05/03/12 07:15 PM
SD
Z
zrxkawboy Offline OP
Z
SD
The thread on the overheating 67 Belvedere got me thinking, but I didn't want to hijack the thread. This is something I've wondered about from time to time: why do some people not run vacuum advance on street-driven cars? I'm sure no expert, but it seems to me that it would always be beneficial. Any thoughts?
It's Swifty! Swifty, you toad sucker!
Re: vacuum advance [Re: zrxkawboy] #1226849
05/03/12 07:20 PM
05/03/12 07:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Well for one, drag cars don't us mechanical advance so some people plug it thinking that it will give them a performance increase.
More likely they re-curved their distributor, or set the timing to get more total advance, or over advanced their timing. Either way some effort has been made to tune the car with a more aggressive timing curve for more power. Then they run into issues at part throttle (usually in high gear on hills) with detonation, so plugging the vacuum advance cures this. I don't like plugging the vacuum advance, it makes a lot of cars (particularly automatics) feel very sluggish under normal driving. But to each their own. Sometimes it may be necessary but I think it often gets plugged when it shouldn't be.
Re: vacuum advance [Re: GTX MATT] #1226850
05/03/12 09:08 PM
05/03/12 09:08 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
I have run my smblk cuda with and with out.
My experinace has been varied. With the vac advance hooked up to ported vac (above the throtle blades) the car bucks and jumps under slow crusing speeds and decell. Tried to tune it out but no luck.
With the vac advance hooked to constant vac, below thotle bades, the idle smoothed out (increase timing), but under part throtle cruise, highway speed, the car ran incredbibly lean / stinky and 10 - 15 deg hotter than normal. Really not good! Had to stop 45 min into a road trip to disconnect the vac advance.
With the vac adacne disconnected, the car runs well, idelas well (choppy but that is the idea).
Re: vacuum advance [Re: zrxkawboy] #1226851
05/03/12 09:14 PM
05/03/12 09:14 PM
the house on the left.
cogen80 Offline
cogen80  Offline
because guy are scared to mess with it, don't understand it, or just old and stubborn.
Re: vacuum advance [Re: zrxkawboy] #1226852
05/03/12 09:28 PM
05/03/12 09:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
define your "street driven car" it's not really needed for anything but economy. If you have even a mild 440 Lock the sucker in at 38* and be on your way. The MPG different will be minimal at best. However if your junk is advancing up to 50-55* you could hurt something.
Coming soon!!!!
Re: vacuum advance [Re: Mr.Yuck] #1226853
05/04/12 09:44 AM
05/04/12 09:44 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
In my efforts to make my stroker more streetable, I had a vacuum advance distributor set up by 4 seconds flat. Replaced my non-vacuum tach drive distributor. After swapping and some carb tweaking, I have to say that it is better.
Re: vacuum advance [Re: rbstroker] #1226854
05/04/12 10:31 AM
05/04/12 10:31 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i got away from the full centrifugal only distributor for street driving many years ago. a vacuum advance distributor is better for street use. lets the engine burn cleaner.
Re: vacuum advance [Re: lewtot184] #1226855
05/04/12 10:56 AM
05/04/12 10:56 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..very important feature for street driven cars and your car will run o.k. without it but you're leaving a lot on the table.
google "timing and vacuum advance 101".. and you will be without excuse
Re: vacuum advance [Re: can.al] #1226856
05/04/12 11:50 AM
05/04/12 11:50 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I guess for me its because I am an old bracket racer from the 70's and under full throttle like drag racing the vacum advance does not work. And I like very fast mech advance as my dist has full advance by 2000 rpm. And it is a race unit without a vacum advance. Right now I have 38 total in very early and it runs great. Never tried a vacum advance but of course I would have to change dist to try it. Ron
Re: vacuum advance [Re: Mr.Yuck] #1226857
05/04/12 12:01 PM
05/04/12 12:01 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Locked out dizzy eh? Guess some people refuse to move ahead 40 years
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: vacuum advance [Re: DARTH V8Я] #1226858
05/04/12 12:08 PM
05/04/12 12:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Wow yuck, better read up before posting.
Re: vacuum advance [Re: 383man] #1226859
05/04/12 12:52 PM
05/04/12 12:52 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
in my 65 coronet i use an aggressive centrifugal advance with the vacuum. at first i didn't think it would work but it seems to be a happy set-up. the distributor has a 9 degree plate, full centrifugal is all in at 2200rpm, and a 9 degree vacuum can. i'm sure the engine is burning cleaner with it, especially at cruise, and of course at full throttle the vacuum advance doesn't work.
Re: vacuum advance [Re: lewtot184] #1226860
05/04/12 06:13 PM
05/04/12 06:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm also lining up on the 'use it' side. i have played with it both ways and while i won't say my modified 440 6pack setup is a turd without it (how can such awesomeness ever be one) there is a huge difference on the street in 'seat-of-the-pants feel and response.
Re: vacuum advance [Re: mikemee1331] #1226861
05/04/12 06:25 PM
05/04/12 06:25 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I prefer to use vacuum advance for street driving but I limit it to 10/12 degrees. Mechanical is all in by 2500 rpm and vacuum is connected to the manifold. I've ran both ported vacuum and manifold vacuum and had good results with both on different engines. Manifold vacuum suits my current set-up, it idles a lot better with the additional advance so that's what I run. Also tried disconnecting the vacuum advance and my right foot is nearer the carpet when I'm cruising.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: vacuum advance [Re: zrxkawboy] #1226862
05/04/12 07:27 PM
05/04/12 07:27 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The bottom line: If you don't have at least 50-55 deg. (total) at lightest throttle / cruise, you're making the Arabs rich and cutting ring / cyl wall life in half!
Assuming you have a canister that's marked. say, 8 deg. on the arm (16 crankshaft degrees), you'll be close to dialed in as far as overall advance with the typ. 33-35 deg. (total of initial and mech). You vary the spring pressure on the back of the diaphragm to tune out any detonation.
This is not very different than virtually all muscle-era Mopar distributors were stock.
Rick
Re: vacuum advance [Re: Rick_Ehrenberg] #1226863
05/04/12 07:42 PM
05/04/12 07:42 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Rick
Is there an upper end of too much vac advance? I think I saw 60* on my timing tape the other day I really need to get a mity-vac to test it properly. I don't remember how many degrees it has stamped on the arm.
Re: vacuum advance [Re: hooziewhatsit] #1226864
05/04/12 07:51 PM
05/04/12 07:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you're not getting any detonation while at cruise or a very light acceleration then I'd say you're fine.
Re: vacuum advance [Re: hooziewhatsit] #1226865
05/04/12 07:57 PM
05/04/12 07:57 PM
IN
ahy Offline
ahy  Offline
IN
As I understand it, the goal is to light the fire early (advanced) so you get maximum cylinder pressure built up near TDC. The efficiency gain comes from getting the benefit of that pressure for the full power stroke plus higher peak pressure near TDC.
With a "fast burn" combustion chamber lighting the fire too early could get max pressure before TDC and really fight the piston going up. Plus it could cause detonation.
Slow burn chambers like the 906 can benefit from more advance than the fast burn.
On my (sort of) fast burn BB with closed chamber Ed heads I have it set at 50 degrees via EFI. If I could figure out how to do it I'd paste the advance table. Is this optimal? I don't know It would take quite some testing and/or experiments to figure out. I do know it works well. The engine runs well and will get 14 MPG @ 75 MPH or the same on a 2 lane @ 65 MPH with an occacional blast for passing. Not bad for a 496 with 243 @.050 cam.
Re: vacuum advance [Re: DaytonaTurbo] #1226866
05/04/12 08:00 PM
05/04/12 08:00 PM
Well, I'm not getting any that I can hear over general engine/road/wind/rattle noise
Re: vacuum advance [Re: ahy] #1226867
05/04/12 08:15 PM
05/04/12 08:15 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
If you have a knock sensor that would be optimal. The computer will give as much advance as possible. Watching my Truck, it'll try and 'hold' 50 degrees at all throttle conditions (cept' for full throttle). I generally never see it go lower then 35 or so even with a very heavy load.
