fluctuating fuel pressure #1226694
05/03/12 11:31 AM
05/03/12 11:31 AM
Fairview Tennessee
SV_MOPARS Offline OP
Fairview Tennessee
maybe one of you guys can give me an idea of why my fuel pressure is changing for no good reason, if i set f/p at 6-7 lbs it will drop down to 3-4 or sometimes it will be up around 11 lbs, i have a barry grant 220 h/r pump feeding 2 demon 850 blower carbs which are junk imo on an 871 fed by a -10 with a -8 return, i bought the pump about 6-7 years ago and just got the car finished and running, i have used this setup before with no problems, not that it should matter but i will be changing the carbs out to a set of quick fuel blower carbs, any input would help.
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226695
05/03/12 12:33 PM
05/03/12 12:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are you running pump gas ? Ron
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226696
05/03/12 02:29 PM
05/03/12 02:29 PM
Is your fuel pressure gauge liquid filled? If so drain it and go from there
Re: fluctuating fuel pressure [Re: Cab_Burge] #1226697
05/03/12 02:48 PM
05/03/12 02:48 PM
Fairview Tennessee
Fairview Tennessee
yes i'm running pump gas with "stabil" additive, the gauge is liquid filled, how is that a problem?
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226698
05/03/12 03:43 PM
05/03/12 03:43 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226699
05/03/12 04:12 PM
05/03/12 04:12 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
The pressure will drop on the guage when the liquid heats up. Also the return line needs to be bigger than the feed line.
Yeah, it's got a smallblock.
Re: fluctuating fuel pressure [Re: 340B5] #1226700
05/03/12 04:19 PM
05/03/12 04:19 PM
Moparnut426 Offline
Moparnut426  Offline
Never heard of that, I thought an autometer guage thats liquid filled is about the most accurate style of guage there was?? I would think they might want to use a non expanding form of liquid. But that might be why they are not filled all the way to allow for the expansion.
Lear something every day I guess.
Re: fluctuating fuel pressure [Re: 340B5] #1226701
05/03/12 04:20 PM
05/03/12 04:20 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Are you running a constant voltage to your FP???
I should of said consistant voltage.
Re: fluctuating fuel pressure [Re: Moparnut426] #1226702
05/03/12 04:55 PM
05/03/12 04:55 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I was having that problem with pressure going up and down...I drained my liquid filled gauge and...ROCK STEADY gauge....
that return line needs to be the same size as the supply...
Re: fluctuating fuel pressure [Re: A57_RT ] #1226703
05/03/12 09:07 PM
05/03/12 09:07 PM
Fairview Tennessee
Fairview Tennessee
as far as i know it is getting consistant voltage, its on a relay, i will have to check, i think i will start with the gauge, somebody did mention that the return should be the size of the feed or bigger,i'm not doubting that, but i just can't see it creating that much of a fluctuation.
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226704
05/03/12 10:46 PM
05/03/12 10:46 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
liquid filled guages are bad mojo
Re: fluctuating fuel pressure [Re: Moparnut426] #1226705
05/03/12 11:21 PM
05/03/12 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Liquid filled gauges are great in a constant temp
environment but when the oil in them heats up it
pushes back on the measuring tube inside the gauge...
normally with the filled gauges they show a lower
pressure than whats really there(in a under hood
environment)with increasing temps..... to the OP...
drain the gauge first... there is a rubber plug
on the top... pull it and let it drain out.. either
leave the plug out or put a small hole in the plug
so it can vent ... then check your system again
Re: fluctuating fuel pressure [Re: MR_P_BODY] #1226706
05/04/12 01:16 AM
05/04/12 01:16 AM
Fairview Tennessee
Fairview Tennessee
thanks for that info mr p body, i was hoping you would chime in, you always seem to have a good answer or response.
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226707
05/04/12 01:37 AM
05/04/12 01:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No problem... my buddy had the same issue on drag week
2 years ago(pressure was dropping according to his
filled gauge) but he didnt believe it was the gauge
so when he went to check out one of the cars I drained
it and just left the plug out... when he got back
I told him I found the problem and fixed it... so
when he fired it up then looked at the gauge it was fine
and he asked what I did... I told him... he still
didnt believe me.... LOL
Re: fluctuating fuel pressure [Re: MR_P_BODY] #1226708
05/05/12 11:34 PM
05/05/12 11:34 PM
Fairview Tennessee
Fairview Tennessee
drained the fuel pressure gauge and readjusted the regulator, took the car out for a few more shake down miles and it seams to be holding at 6 1/2 lbs, hopefully she will hold , thanks for the input.
Re: fluctuating fuel pressure [Re: SV_MOPARS] #1226709
05/06/12 12:02 AM
05/06/12 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad you got it squared away
