Questions on this Rare Optioned Fender Tag #1226668
05/03/12 10:24 AM
05/03/12 10:24 AM
Cali
U
usmuscle Offline OP
usmuscle  Offline OP
U
Cali
Below is the decoded fender tag from my Charger. I have 2 questions on this.
1.) Is this a possibly a 2 tag car and I am missing one? Looks like some basic options are missing (top type, type of braking system, glass....)
2.) The registry says that A32 - Dana 60 Performance package was not available with A/C. This car has H51 Air. Does that make this a super rare combo (I know its rare to begin with...) or am I reading this wrong...
Code Description
E86 440-4 Barrel High Preformance
A32 4.10:1 Dana 60 Performance Package
XS29
X = Dodge Charger
S = Special
29 = 2 Door Sports Hardtop
U0G
U = 440 375HP 1-4BBL 8 CYL
0 = 1970
G = St. Louis, MO, USA
111111 Sequence Number '111111'
EK2
Paint Code: Go-Mango / Vitamin C Orange
C5XA
Trim Grade/Style/Color
C = Charger
5 = Cloth and Vinyl Bucket Seats
X = Black
TX9 Upper Door Frame: Black / Black Velvet
B28 Date Built: 12 / 20 / 1969
060203 Order Number: 061333
EK2 Go-Mango / Vitamin C Orange
B51 Power Assisted Brakes
C16 Console w/ Buckets
C55 Bucket Seats
H51 Single Air /w Heater
J45 Hood Tie Down Pins
M21 Roof Drip Rail Moldings
M31 Belt Molding 69-70
R11 Music Master Radio AM
V6X Black Longitude Sports Stripe
26 26 in. Radiator
Thank you!
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226669
05/03/12 10:35 AM
05/03/12 10:35 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
The fender tag options look pretty typical of a 70 Charger R/T. This is not a 2 fender tag car as the stripe code & 26 are usually the last items on a St. Louis tag. The top color is on the tag as EK2, the power brakes are also noted as B51....you did not show the A32 option code in the correct order so I assume this car did not come with it. I assume you have a D32 as the second option code noted on the lowest line. This is for auto trans. Car sounds nice as optioned. How about a few photos?
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226670
05/03/12 10:38 AM
05/03/12 10:38 AM
Yonkers N.Y
GTSfanatic Offline
GTSfanatic  Offline
Yonkers N.Y
The 3 digit code right next to the engine code (E86)on the lower line is the transmission code, which should be D32 for an auto transmission (727). Most likely a mistake at the factory or a repro tag. Pics would do wonders here.
1968 Dart GTS 340 Auto...White, Red Int
Re: Questions on this Rare Optioned Fender Tag [Re: GTSfanatic] #1226671
05/03/12 10:51 AM
05/03/12 10:51 AM
Cali
U
usmuscle Offline OP
usmuscle  Offline OP
U
Cali
I didn't realize it wasn't on the option list, but this is a 4 speed car. The numbers all match still.
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226672
05/03/12 11:12 AM
05/03/12 11:12 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Pictures would solve the mystery.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226673
05/03/12 11:37 AM
05/03/12 11:37 AM
Yonkers N.Y
GTSfanatic Offline
GTSfanatic  Offline
Yonkers N.Y
A32= Super performance axle package. available with 426 hemi and 440 automatic transmissions only
A34 = Super Track pack. available with 426 Hemi and 440 4 speed cars only
both options not available with A/C
Re: Questions on this Rare Optioned Fender Tag [Re: GTSfanatic] #1226674
05/03/12 12:02 PM
05/03/12 12:02 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
You listed B51 Power brakes in your decoding.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226675
05/03/12 12:03 PM
05/03/12 12:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Code Description
XS29
X = Dodge Charger
S = Special
U0G
0 = 1970
EK2
C5XA
C = Charger
X = Black
C55 Bucket Seats
26 26 in. Radiator
Thank you!
The only thing "rare" about the car, is it has survived over the last 4 decades, nothing more, nothing less.....but it's a cool ride none the less
Re: Questions on this Rare Optioned Fender Tag [Re: GTSfanatic] #1226676
05/03/12 12:06 PM
05/03/12 12:06 PM
DPelletier Offline
DPelletier  Offline
A34 = Super Track pak. available with 426 Hemi and 440 4 speed cars only
- A32 isn't available with H51....it isn't rare, it just isn't period.
- A32 shouldn't be on the tag in the order shown. It probably should be D32 - automatic tranny.
- A32 (superperformance axle package 4.10 Dana) isn't available on a 4spd car (would be A34 Super Track Pack)
I suspect either you've made a typo or the fender tag is a poor reproduction. tranny stamps may not be original.
Pics will tell the tale one way or the other, but don't post them if you don't really want to know.
Re: Questions on this Rare Optioned Fender Tag [Re: DPelletier] #1226677
05/03/12 12:07 PM
05/03/12 12:07 PM
DPelletier Offline
DPelletier  Offline
Re: Questions on this Rare Optioned Fender Tag [Re: DPelletier] #1226678
05/03/12 12:08 PM
05/03/12 12:08 PM
DPelletier Offline
DPelletier  Offline
Re: Questions on this Rare Optioned Fender Tag [Re: usmuscle] #1226679
05/03/12 01:09 PM
05/03/12 01:09 PM
Lansing, MI
Lansing, MI
If it is an original 4 speed car the tag will have D21 as the second option code on the first line. D21 was not available with H51 A/C on a 70 Charger.
Re: Questions on this Rare Optioned Fender Tag [Re: 70gtx440dana] #1226680
05/03/12 01:41 PM
05/03/12 01:41 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
As mentioned earlier, the A32 is most likely D32.
Only thing special about that tag is it's missing the transmission code.
B28 is November 28, 1969
Re: Questions on this Rare Optioned Fender Tag [Re: RobX4406] #1226681
05/03/12 02:49 PM
05/03/12 02:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What they said , the A32 is in the position that the trans code is placed , it's either D32 or someone , somewhere , screwed up.
You say the car is a 4 speed car, there is not D21 in your decode, how about posting a picture of the tag , block out the VIN if you are concerned .
Re: Questions on this Rare Optioned Fender Tag [Re: JohnRR] #1226682
05/03/12 02:52 PM
05/03/12 02:52 PM
Lansing, MI
Lansing, MI
Here is a tag that should look very much like the one on this car...this is the same production date. This car however is a Charger 500 not an R/T.
Re: Questions on this Rare Optioned Fender Tag [Re: 70gtx440dana] #1226683
05/03/12 03:02 PM
05/03/12 03:02 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
If it is an original 4 speed car the tag will have D21 as the second option code on the first line. D21 was not available with H51 A/C on a 70 Charger R/T .
D21 with H51 is fine on XH or XP Charger
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Questions on this Rare Optioned Fender Tag [Re: 69CoronetRT] #1226684
05/03/12 03:04 PM
05/03/12 03:04 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Is it correct this is not the right VIN number and you are just using it as place holders?
Seeking:
Re: Questions on this Rare Optioned Fender Tag [Re: DPelletier] #1226685
05/05/12 05:51 PM
05/05/12 05:51 PM
Lansing, MI
Lansing, MI
I am surprised this post became so quiet all of the sudden! I expected to see a photo of the fender tag, tranny stamping, engine stamp or some photos of car by now. OP please provide us with more info on this car!!
Re: Questions on this Rare Optioned Fender Tag [Re: 70gtx440dana] #2758602
04/01/20 08:27 PM
04/01/20 08:27 PM
Grand Forks, ND
RottingAmericanC Offline
Grand Forks, ND
If you want to know why you haven't heard a reply, it's because the car is 100% fake. I have been trying to track down information on this sequence car. I know of the real "111111" production sequence car but its vin and trim tag were stolen years ago. The real 111111 car (which I have pictures of the body stampings to prove it) is actually a 318 2bbl automatic car in that bland green color half of all chargers seem to have came in. This is why none of his trim tag codes make sense, someone basically stole the evidence and decided to use the production sequence to create a car that never existed. Unless he can show me the vin, trim tag, and body stampings verifying this car it is likely a fake.
Re: Questions on this Rare Optioned Fender Tag [Re: RottingAmericanC] #2758656
04/01/20 10:56 PM
04/01/20 10:56 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Not sure what the point is, you joined Moparts to reply to a nearly 8 year old post to someone that hasn't been on the site in nearly as long. The OP posted a total of 6 times and hasn't been on since. It's a little late to be calling him out about a fake VIN.
