Questions on this Rare Optioned Fender Tag
#1226668
05/03/12 10:24 AM
05/03/12 10:24 AM
Posts: 6 Cali
usmuscle
Cali
Below is the decoded fender tag from my Charger. I have 2 questions on this. 1.) Is this a possibly a 2 tag car and I am missing one? Looks like some basic options are missing (top type, type of braking system, glass....) 2.) The registry says that A32 - Dana 60 Performance package was not available with A/C. This car has H51 Air. Does that make this a super rare combo (I know its rare to begin with...) or am I reading this wrong... Code Description E86 440-4 Barrel High Preformance A32 4.10:1 Dana 60 Performance Package XS29 X = Dodge Charger S = Special 29 = 2 Door Sports Hardtop U0G U = 440 375HP 1-4BBL 8 CYL 0 = 1970 G = St. Louis, MO, USA 111111 Sequence Number '111111' EK2 Paint Code: Go-Mango / Vitamin C Orange C5XA Trim Grade/Style/Color C = Charger 5 = Cloth and Vinyl Bucket Seats X = Black TX9 Upper Door Frame: Black / Black Velvet B28 Date Built: 12 / 20 / 1969 060203 Order Number: 061333 EK2 Go-Mango / Vitamin C Orange B51 Power Assisted Brakes C16 Console w/ Buckets C55 Bucket Seats H51 Single Air /w Heater J45 Hood Tie Down Pins M21 Roof Drip Rail Moldings M31 Belt Molding 69-70 R11 Music Master Radio AM V6X Black Longitude Sports Stripe 26 26 in. Radiator Thank you!
Re: Questions on this Rare Optioned Fender Tag
[Re: usmuscle]
#1226669
05/03/12 10:35 AM
05/03/12 10:35 AM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
The fender tag options look pretty typical of a 70 Charger R/T. This is not a 2 fender tag car as the stripe code & 26 are usually the last items on a St. Louis tag. The top color is on the tag as EK2, the power brakes are also noted as B51....you did not show the A32 option code in the correct order so I assume this car did not come with it. I assume you have a D32 as the second option code noted on the lowest line. This is for auto trans. Car sounds nice as optioned. How about a few photos?
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: usmuscle]
#1226670
05/03/12 10:38 AM
05/03/12 10:38 AM
Posts: 752 Yonkers N.Y
GTSfanatic
Yonkers N.Y
The 3 digit code right next to the engine code (E86)on the lower line is the transmission code, which should be D32 for an auto transmission (727). Most likely a mistake at the factory or a repro tag. Pics would do wonders here.
1968 Dart GTS 340 Auto...White, Red Int
[Re: usmuscle]
#1226675
05/03/12 12:03 PM
05/03/12 12:03 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Thank you!
The only thing "rare" about the car, is it has survived over the last 4 decades, nothing more, nothing less.....but it's a cool ride none the less
[Re: usmuscle]
#1226679
05/03/12 01:09 PM
05/03/12 01:09 PM
70gtx440dana
Lansing, MI
If it is an original 4 speed car the tag will have D21 as the second option code on the first line. D21 was not available with H51 A/C on a 70 Charger.
[Re: RobX4406]
#1226681
05/03/12 02:49 PM
05/03/12 02:49 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
As mentioned earlier, the A32 is most likely D32.
Only thing special about that tag is it's missing the transmission code.
B28 is November 28, 1969
What they said , the A32 is in the position that the trans code is placed , it's either D32 or someone , somewhere , screwed up.
You say the car is a 4 speed car, there is not D21 in your decode, how about posting a picture of the tag , block out the VIN if you are concerned .
[Re: JohnRR]
#1226682
05/03/12 02:52 PM
05/03/12 02:52 PM
70gtx440dana
Lansing, MI
Here is a tag that should look very much like the one on this car...this is the same production date. This car however is a Charger 500 not an R/T.
