Re: If 1 carb is good , 2 must be better
[Re: sixpackgut]
#1226185
05/04/12 03:43 PM
05/04/12 03:43 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
interested to know how even your plugs look on each cylinder. surging is a lean condition. what size engine is this setup on?
Dan at Performance only made me a couple lids that match the barrel sizes of the 650 avs carbs. I use the chokes on the carbs and the car runs every bit as good as my daily driver now. its really amazing. the only thing I did to the carbs was change the pumps in the carbs. I dont have any dyno or track info though to compare it to my six pack setup I had on it.
Is it possible to get the plenum too big? If so, how do you know what is too big of an area or too small?
[Re: Dodgeguy101]
#1226186
05/04/12 04:22 PM
05/04/12 04:22 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i have done a bunch of research on this very subject. i was worried about mine but from what i have read, an engine would want a plenum the same CI or larger as the engine. Some prefer up to 150%. my plenum on the sheetmetal ram i posted comes in at around 410 CI compared to my 493 engine. the plenum on my weiand tunnel ram i was useing is much smaller
look at the plenum size of the Indy bathtube intake and it seems to work very well except for the fact that it has alot of places for fuel to puddle
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1226187
05/05/12 07:59 AM
05/05/12 07:59 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
thanks for the ideas. went out again car ran the same but the driver - damn nut behind the wheel.anyway good to watch some doorslammers,prostock,alky and nitro cars.even had a chat with Cory Mac who is over here to race this weekend after a lot of thought and talking to others i guess i have a game plan of sorts. i have a Prostreet meeting in 2 weeks so will swap back to the single carb,picks back up et and some mph. it may simply be the modman plenum may simply be too large for my ci and rpm range.i have a 440+0.055 ,leave off the footbrake at 2500-2700, shift at 6000,trap 635-6450.this could lead to a poor signal hence having to jet up a lot and leading to a lazy launch.with the manifold off i can set up a cross shaped insert to not only reduce volume but also maybe help direct and speed up the airflow. a mate of mine who races a stroked 409(476ci) chev W motor said Lamar Waldren does a similar intake for these motors and some guys using stock ci or lower RPM motors were finding they needed inserts to get the best results.i may also try something in my M1. so i can see improvements to come . BUT it may be this manifold may suit a stroker motor more readily,particularly in a six pack setup. as to bigger cfm carbs i would think there would be an even more reduced signal,though with an improved signal they might work. i know on my motor when i tried a ultrahp 950 about a year ago the car lost 3/10 and nearly 3 mph over my BG825.and a hp1000 based carb goes a little better et and mph. as the saying goes - "your experiance may vary" ![](/ubbthreads/images/graemlins/Twocents.gif) Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Clanton]
#1226189
05/05/12 09:57 AM
05/05/12 09:57 AM
sixpackgut
Charleston
i dont think the plenum volume is the problem, I think the short runners are
[Re: sixpackgut]
#1226191
05/05/12 11:00 PM
05/05/12 11:00 PM
tex013
Sydney,Australia
sixpack, that is also consideration of building an insert to help direct air into the runners.almost like extending them. MrYuck, i also think holley type carbs would be better but won't fit this top.Maybe a type like shown by A57RT in the small block manifold thread would As to tuning at the track i did try a couple of rod and spring changes.Best 60' was with the most fuel and silver spring.But with the silver spring there was some surge,rich,at light idle.Yellow springs are fine.I did find without the silver spring on the dyno and road,but not strip,there was a heasitation as you hit the throttle to the floor from cruise.so it does look like a signal issue leading to fuel issues oh well 1 step forward - 2 steps backward. all in the pursuit of speed
Tex
[Re: tex013]
#1226192
05/05/12 11:53 PM
05/05/12 11:53 PM
sixpackgut
Charleston
Tex, on my 650 avs carbs i took out the stock pump and put in the one that comes in the 800 carbs. I also drilled my squirters out from .031 to .037
stock on left. you can see the differnce
[Re: sixpackgut]
#1226193
05/06/12 06:48 PM
05/06/12 06:48 PM
tex013
Sydney,Australia
Sixpack thanks for the pic took the manifold off yesterday arvo and will play around with insert style over the next week or two.Will also talk to Ben at Promax . I do see a better result as looking at mph i am not far off the power now i am stuffed why the pics are so low resolution,will try again
Tex
[Re: Cudajon]
#1226196
05/07/12 07:00 PM
05/07/12 07:00 PM
tex013
Sydney,Australia
Cudadon, i don't have too much of an issue with clearance as i have a six pack scoop/hood,i can prob go 2" spacer no worries and still run a 3" filter A57RT, i will try spacers,but want to get a insert done as well.easier to make up off car.plus like i said have a meeting on the 19th thanks for the ideas.
Tex
[Re: tex013]
#1226197
05/14/12 09:20 PM
05/14/12 09:20 PM
Posts: 18 Beyond the sun
Bakerlite
Beyond the sun
Tex, It's about time I gave you something to think about. You've been swapping cams, carbs, manifolds, jetting etc to no avail. You've got a massive fuel system so , delivery, jetting etc is not going to be the problem. The cam swap was a bit of a stab in the dark because when you put that cam in the other motor it had way too may variables being changed at the same time as well as having different cubes and heads. Although you did see a power increase in that engine,there was no way to say for sure how much extra power was being delivered by just the cam. Infact your own engine may have not realized the full potential of that cam or the new one you have put in because of one factor. Your cylinder heads. You and I have talked about this before. I'd say they are the choke point of your engine. Although they are ported, they were done by a guy without the aid of a flow bench and who knows what quantifiable experience he has, as head porter. This could mean your heads flow better, the same, or worse than straight out of the box. You have no data to go by on this subject. You have always had the attitude that your "RV" cam was what was determining the performance of your engine, when infact it was most likely the biggest cam that your combination would accept. I think it's time for you to seriously take a look at these heads because your spending $$ hand over fist and going in circles.
