Re: Silicon Brake Fluid - good, bad??
[Re: mrdodge69]
#122620
09/18/08 02:37 PM
09/18/08 02:37 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I run it in my Dart with no problems. I have heard it can be a little more difficult to blead as it can have micro bubbles in it that are hard to detect. But all good with mine.
As have I in my E body.
SAE did a tech brief on this subject a year or two ago. If I remember correctly, they suggested that you stick with DOT3 as it gives better performance overall. If you use silicone they suggested you completely change the silicone every couple of years.
That said,
I had silicone never changed in my e body for 7 years with no problems.
[Re: Dart 340]
#122621
09/18/08 03:39 PM
09/18/08 03:39 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I am completely rebuilding the brake system from master cylinder back except for the steel lines. This includes new rear wheel cylinders, front calipers and rubber hoses troughout. Would compressed air sufficiently clean out the steel lines of old dot3 if I chose to switch to silicon? Or should I flush with alchohol or something else?
[Re: Scott Carl]
#122622
09/18/08 05:11 PM
09/18/08 05:11 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Blowing out the lines with air will be sufficient, a small amount of residual DOT3 fluid won't cause any problem when converting to silicone.
[Re: conv440]
#122623
09/18/08 06:16 PM
09/18/08 06:16 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The good: It doesn't absorb moisture (read less rust), it won't melt your paint if you spill it, it also supposedly compresses less so you get a firmer pedal. It may also have higher operating temps (not sure on that one).
Silicone fluid does not absorb moisture but that means that the water will seperate and collect in spots and can cause corrosion. So if you don't flush silicone, rust issues can be worse than DOT, also there is the water boiling aspect too.
And Silicone fluid does compress and makes for a spongier pedal.
Despite that, I run it and like it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#122625
09/18/08 07:28 PM
09/18/08 07:28 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
You will hear the naysayers say all the bad things like water will collect in the lines and rot a hole through the line, among other things. I have been using it exclusively for the last 20+ years on all my own and the cars I build for others with NO issue. All it takes is for one drop to ruin a freshly painted car. , and you will never use the DOT 3 again. Conversely, I am not proclaiming that you need to purge every car you own and put the silicone fluid in, just that the special cars, restorations etc. should use the stuff. Works great on the tires, too. MB
[Re: gomangoRTSE]
#122627
09/18/08 08:42 PM
09/18/08 08:42 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The post office has been using it for years in the older mail delivery vehicles.No problems with it ever and it does not harm anything or collect moisture.
