If 1 carb is good , 2 must be better
#1226164
05/02/12 07:34 PM
05/02/12 07:34 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Well i got my Indy Modman yesterday,fitted straight away Thanks to BG Racing for his help and information as to his experience. thanks to Promax for the supply of the kit and all extras. Now to see the dyno this afternoon and racing at the Nitro Championships this weekend. Will post dyno later today if possible http://i1018.photobucket.com/albums/af301/texsautomotive/SANY0135.jpghttp://i1018.photobucket.com/albums/af301/texsautomotive/SANY0136.jpgTex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: If 1 carb is good , 2 must be better
[Re: tex013]
#1226167
05/02/12 08:33 PM
05/02/12 08:33 PM
Posts: 5,620 long island NY
Ari440
long island NY
NICE do you have any bigger pics is it standerd ports or maxwedge ports how tall is the manifold and with carbs how close is it to your sixpack hood
1.39 9.85 - 137 mph
[Re: Ari440]
#1226170
05/02/12 10:40 PM
05/02/12 10:40 PM
tex013
Sydney,Australia
Ari, it is the same height as my M1 single plane.stock port size.heaps of room to my six pack scoop,so much i will use 2 air cleaners stacked-Edelbrock #1235.there are no spacers under the carbs. just finished modifying my fresh air box with a mate. will try to get some better pics later. Dunnuck - i am hoping with 1:1 linkage there should be little problem setting the carbs,i have done a couple so fingers crossed on my car Tex
[Re: Cudajon]
#1226172
05/03/12 12:16 AM
05/03/12 12:16 AM
tex013
Sydney,Australia
Ari, i forgot to note there appears plenty of meat to go max wedge port size.i know you can order either
Tex
[Re: hemi-itis]
#1226179
05/04/12 06:31 AM
05/04/12 06:31 AM
tex013
Sydney,Australia
well just got back from qualifing for the Nitro Championships,long day for 3 runs. Went on the dyno yesterday afternoon. Got to say the results so far have been disappointing.Though i feel there is more to go. On the dyno i ended up with close to 15RWHP down only 391/393.This is with the carbs 1-1 linkage.There was timing and jetting changes. I seem to have a similar issue to what in that i just cannot get enough fuel into the motor,I have 1405 eddy's and the strip kit to suit.i ended up with #18 primary side setting and 2 steps richer on the secondary and still barely got into the high 12's AFR and with a silver step spring it would go low 12's on tip in. the car drove ok but on light throttle had a little surge.this seems to have gone with a blue spring. that's the dyno tell them about the dragstrip son Unfortunately the same result,dropped between 1 and 2 1/10's.Plus a little MPH,could not get into the 119's Most if not all the loss is in the 60'.i normally average 1.54.today i started at 1.572 for a 11.245@118.91,1.651 for a 11.332@118.95,11.628 for a 1111.328@118.91i am fresh out of ideas today and won't have time to swap back on the old manifold. i have to say the car launches really lazy and doesn't even pull the front wheels from looking at the video thoughts appreciated i'll just have to suckup having a slow car this weekend Tex
[Re: tex013]
#1226181
05/04/12 09:38 AM
05/04/12 09:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
A member here was putting in 2 needle and seats per carb on those...(Jake68 I believe) to get more fuel
[Re: snook]
#1226183
05/04/12 11:13 AM
05/04/12 11:13 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
interested to know how even your plugs look on each cylinder. surging is a lean condition. what size engine is this setup on?
Dan at Performance only made me a couple lids that match the barrel sizes of the 650 avs carbs. I use the chokes on the carbs and the car runs every bit as good as my daily driver now. its really amazing. the only thing I did to the carbs was change the pumps in the carbs. I dont have any dyno or track info though to compare it to my six pack setup I had on it.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
